  3. Need Help Troubleshooting SOC Encounter Violations
  • Subscribers 94
  • Views 15693
INSANI
INSANI over 15 years ago
I am working on a DTMF tutorial on Cadence SOC Encounter 9.1. Since this  is my first time i am unable to even decide what to do to remove my errors.
Presently i have completed CTS and verified the design by connections and geometry.
I got almost all of the error after the verification step.
I am getting 20 connectivity/open violations and 1000( :( ) short violations.
The log file content is below:
******** Start: VERIFY CONNECTIVITY ********
Start Time: Wed May  4 22:07:40 2011
Design Name: DTMF_CHIP
Database Units: 2000
Design Boundary: (0.0000, 0.0000) (1686.3850, 1663.3200)
Error Limit = 1000; Warning Limit = 50
Check all nets
**** 22:07:41 **** Processed 5000 nets (Total 6490)
Open violation {207.720 207.720 1478.665 1455.600} is too complicated to show its polygon outline. It will be marked with its bounding box.
Net VDD: special open.
VC Elapsed Time: 0:00:01.0
Begin Summary
    20 Problem(s) (ENCVFC-200): Special Wires: Pieces of the net are not connected together.
    20 total info(s) created.
End Summary
End Time: Wed May  4 22:07:41 2011
******** End: VERIFY CONNECTIVITY ********
  Verification Complete : 20 Viols.  0 Wrngs.
  (CPU Time: 0:00:00.9  MEM: 2.723M)
encounter 4>  *** Starting Verify Geometry (MEM: 419.0) ***
  VERIFY GEOMETRY ...... Starting Verification
  VERIFY GEOMETRY ...... Initializing
  VERIFY GEOMETRY ...... Deleting Existing Violations
  VERIFY GEOMETRY ...... Creating Sub-Areas
                  ...... bin size: 8320
  VERIFY GEOMETRY ...... SubArea : 1 of 4
  VERIFY GEOMETRY ...... Cells          :  0 Viols.
**WARN: (ENCVFG-103):   VERIFY GEOMETRY did not complete: Number of violations exceeds the Error Limit [1000]
VG: elapsed time: 1.00
Begin Summary ...
  Cells       : 0
  SameNet     : 0
  Wiring      : 0
  Antenna     : 0
  Short       : 1000
  Overlap     : 0
End Summary
  Verification Complete : 1000 Viols.  0 Wrngs.
**********End: VERIFY GEOMETRY**********
 *** verify geometry (CPU: 0:00:00.7  MEM: 46.3M)
encounter 4> Redoing specifyClockTree ...
Checking spec file integrity...
Writing Netlist "DTMF_CHIP_verify.enc.dat/DTMF_CHIP.v.gz" ...
**WARN: (ENCSYC-6105):  Option '-pt' is obsolete. The option is ignored in this release, but to avoid this warning, and to ensure compatibility with future releases, donot use this option.
**WARN: (ENCSYC-6108):  Option '-filePrefix' is obsolete. This option still works in this release, but to avoid this warning, and to ensure compatibility with future releases, donot use this option. Use '<filename>' option instead.
Saving clock tree spec file 'DTMF_CHIP_verify.enc.dat/DTMF_CHIP.ctstch' ...
Saving configuration ...
Saving preference file DTMF_CHIP_verify.enc.dat/enc.pref.tcl ...
Saving floorplan ...
Saving Drc markers ...
... 1020 Drc markers are saved ...
Saving placement ...
*** Completed savePlace (cpu=0:00:00.0 real=0:00:00.0 mem=439.0M) ***
Saving route ...
*** Completed saveRoute (cpu=0:00:00.2 real=0:00:00.0 mem=439.0M) ***
*** Completed saveYieldMap (cpu=: 0:00:00.0 real=0:00:00.0 mem=: 0.000M) ***
Creating constraint file...
encounter 4>
I have also added the violation report for your reference.. please prompt me if you need any other files.
If required i will upload whole project file.
[CODE]###############################################################
#  Generated by:      Cadence Encounter 09.11-s082_1
#  OS:                Linux i686(Host ID Ani.INS-ANI.com)
#  Generated on:      Wed May  4 22:22:37 2011
#  Command:           violationBrowserReport -all -no_display_false -report ...
*********** SOC ENCOUNTER Violation Browser Report **********
Report File Name :  DTMF_CHIP.viols.rpt        Page : 1
***************** Report Summary *****************
Num Violation Total                        1020
   Verify                             1020
      Connectivity              20
         Open             20
      Short                     1000
         Short            1000
*************** End Report Summary ***************
Verify - Connectivity - Open Violations ( 20 )
Net VDD
False : No      Bounds (1340.460, 395.520) (1351.020, 396.320)
Net VDD
False : No      Bounds (1340.460, 405.600) (1351.020, 406.400)
Net VDD
False : No      Bounds (1340.460, 425.760) (1351.020, 426.560)
Net VDD
False : No      Bounds (1340.460, 445.920) (1351.020, 446.720)
Net VDD
False : No      Bounds (1344.695, 455.180) (1345.505, 455.180) (1345.505, 455.520) (1345.270, 455.520) (1345.270, 456.000) (1351.020, 456.000) (1351.020, 456.800) (1340.460, 456.800) (1340.460, 456.000) (1344.930, 456.000) (1344.930, 455.520) (1344.695, 455.520)
Net VDD
False : No      Bounds (1344.420, 1060.800) (1351.020, 1061.600)
Net VDD
False : No      Bounds (1344.420, 1070.880) (1351.020, 1071.680)
Net VDD
False : No      Bounds (1344.420, 1080.960) (1351.020, 1081.760)
Net VDD
False : No      Bounds (1344.420, 1161.600) (1351.020, 1162.400)
Net VDD
False : No      Bounds (1344.420, 1191.840) (1351.020, 1192.640)
Net VDD
False : No      Bounds (1344.420, 1212.000) (1351.020, 1212.800)
Net VDD
False : No      Bounds (1344.420, 1222.080) (1351.020, 1222.880)
Net VDD
False : No      Bounds (1344.420, 1232.160) (1351.020, 1232.960)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 2
Net VDD
False : No      Bounds (1344.420, 1242.240) (1351.020, 1243.040)
Net VDD
False : No      Bounds (1344.420, 1252.320) (1351.020, 1253.120)
Net VDD
False : No      Bounds (1344.420, 1262.400) (1351.020, 1263.200)
Net VDD
False : No      Bounds (1344.420, 1272.480) (1351.020, 1273.280)
Net VDD
False : No      Bounds (1344.420, 1282.560) (1351.020, 1283.360)
Net VDD
False : No      Bounds (1344.420, 1292.640) (1351.020, 1293.440)
Net VDD
False : No      Bounds (207.720, 207.720) (1478.665, 1455.600)
Verify - Short - Short Violations ( 1000 )
Regular Via of Net DTMF_INST/clk & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (654.200, 500.800) (654.580, 501.080)
Regular Via of Net DTMF_INST/spi_clk & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (654.200, 540.800) (654.580, 541.080)
Regular Via of Net ibiasI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (355.580, 540.800) (355.600, 541.080)
Regular Via of Net pllrstI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (355.580, 380.800) (355.600, 381.080)
Regular Via of Net refclkI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (355.580, 500.800) (355.600, 501.080)
Regular Via of Net vcomO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (355.580, 420.800) (355.600, 421.080)
Regular Via of Net vcopO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M1     Bounds (355.580, 460.800) (355.600, 461.080)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[23]
False : No      Layer : M2     Bounds (653.590, 766.220) (655.190, 766.500)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[25]
False : No      Layer : M2     Bounds (653.590, 776.300) (655.190, 776.580)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/sel_op_b[2]
False : No      Layer : M2     Bounds (800.770, 640.220) (801.050, 640.500)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[8]
False : No      Layer : M2     Bounds (769.040, 751.100) (769.420, 751.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1006 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[2]
False : No      Layer : M2     Bounds (693.190, 655.340) (693.470, 655.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1023 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907
False : No      Layer : M2     Bounds (745.940, 634.620) (746.320, 634.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1026 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1986
False : No      Layer : M2     Bounds (702.380, 691.180) (702.760, 691.460)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 3
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1029 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 676.060) (687.530, 676.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1029 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 679.980) (687.530, 680.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1029 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1988
False : No      Layer : M2     Bounds (686.590, 676.060) (686.870, 676.340)
False : No      Layer : M2     Bounds (686.590, 679.980) (686.870, 680.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1033 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 676.620) (687.530, 676.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1039 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1915
False : No      Layer : M2     Bounds (703.040, 684.460) (703.420, 684.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1042 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907
False : No      Layer : M2     Bounds (745.280, 640.780) (745.660, 641.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1052 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2004
False : No      Layer : M2     Bounds (681.920, 696.220) (682.300, 696.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1095
False : No      Layer : M2     Bounds (680.600, 715.260) (680.980, 715.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1861
False : No      Layer : M2     Bounds (666.740, 705.180) (667.120, 705.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862
False : No      Layer : M2     Bounds (685.930, 715.260) (686.210, 715.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 705.180) (687.530, 705.460)
False : No      Layer : M2     Bounds (687.250, 710.780) (687.530, 711.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1056 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1066
False : No      Layer : M2     Bounds (744.670, 681.660) (745.660, 681.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1057 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2004
False : No      Layer : M2     Bounds (681.970, 696.780) (682.250, 697.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1063 & Special Via of Net VDD
False : No      Layer : M2     Bounds (694.510, 697.920) (694.790, 698.720)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1068 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1970
False : No      Layer : M2     Bounds (709.690, 660.940) (709.970, 661.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1068 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 660.940) (709.310, 661.220)
False : No      Layer : M2     Bounds (709.030, 674.940) (709.310, 675.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1070 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[5]
False : No      Layer : M2     Bounds (729.490, 756.140) (729.770, 756.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085
False : No      Layer : M2     Bounds (681.310, 640.780) (681.590, 641.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072 & Regular Wire of Net scan_clkI
False : No      Layer : M2     Bounds (672.730, 654.780) (673.010, 655.060)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 4
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1089 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090
False : No      Layer : M2     Bounds (739.390, 710.780) (739.670, 711.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1089 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2029
False : No      Layer : M2     Bounds (738.070, 710.780) (738.350, 711.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_940
False : No      Layer : M2     Bounds (738.730, 721.420) (739.010, 721.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1095 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2038
False : No      Layer : M2     Bounds (679.990, 731.500) (680.270, 731.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1097 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053
False : No      Layer : M2     Bounds (686.540, 715.260) (686.920, 715.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1097 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053
False : No      Layer : M2     Bounds (686.590, 714.140) (686.870, 715.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1097 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1988
False : No      Layer : M2     Bounds (686.590, 685.020) (686.870, 685.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1100 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2039
False : No      Layer : M2     Bounds (674.000, 741.580) (674.380, 741.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1119 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1123
False : No      Layer : M2     Bounds (711.010, 740.460) (711.290, 740.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1132 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[7]
False : No      Layer : M2     Bounds (755.890, 695.100) (756.170, 695.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1135 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2061
False : No      Layer : M2     Bounds (747.310, 734.860) (747.590, 735.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1144 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1857
False : No      Layer : M2     Bounds (695.780, 751.660) (696.160, 751.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1144 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7]
False : No      Layer : M2     Bounds (703.040, 761.740) (703.420, 762.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1144
False : No      Layer : M2     Bounds (709.030, 786.380) (709.310, 786.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1873
False : No      Layer : M2     Bounds (709.690, 785.820) (709.970, 786.100)
False : No      Layer : M2     Bounds (709.690, 802.060) (709.970, 802.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1886
False : No      Layer : M2     Bounds (709.690, 771.820) (709.970, 772.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 776.860) (736.370, 777.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1150 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 775.740) (736.370, 776.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1162 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1084
False : No      Layer : M2     Bounds (730.150, 719.180) (730.430, 719.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1162 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794
False : No      Layer : M2     Bounds (729.490, 684.460) (729.770, 684.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1162 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1800
False : No      Layer : M2     Bounds (735.380, 735.980) (735.760, 736.260)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 5
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1172 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1183
False : No      Layer : M2     Bounds (746.650, 777.420) (746.930, 777.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1173 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068
False : No      Layer : M2     Bounds (739.390, 805.980) (739.670, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1174 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1170
False : No      Layer : M2     Bounds (735.380, 797.580) (735.760, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1174 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2071
False : No      Layer : M2     Bounds (736.750, 791.420) (737.030, 791.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1174 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2085
False : No      Layer : M2     Bounds (736.750, 797.580) (737.030, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1174 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 791.420) (736.370, 791.700)
False : No      Layer : M2     Bounds (736.090, 797.580) (736.370, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1183 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1186
False : No      Layer : M2     Bounds (746.650, 755.580) (746.930, 771.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1186 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_935
False : No      Layer : M2     Bounds (765.130, 790.860) (765.410, 791.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1201 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1198
False : No      Layer : M2     Bounds (728.780, 825.580) (729.160, 825.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1201 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2102
False : No      Layer : M2     Bounds (735.430, 826.140) (735.710, 826.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1211 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1778
False : No      Layer : M2     Bounds (758.530, 794.780) (758.810, 795.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1219 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862
False : No      Layer : M2     Bounds (685.930, 714.700) (686.210, 714.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1219 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870
False : No      Layer : M2     Bounds (685.270, 714.700) (685.550, 716.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1237 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 815.500) (763.430, 815.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1237 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2128
False : No      Layer : M2     Bounds (766.450, 807.100) (766.730, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1237 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933
False : No      Layer : M2     Bounds (765.790, 806.540) (766.070, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1268 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1170
False : No      Layer : M2     Bounds (732.130, 806.540) (732.410, 806.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1286 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[11]
False : No      Layer : M2     Bounds (779.650, 806.540) (779.930, 806.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1286 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[13]
False : No      Layer : M2     Bounds (780.310, 806.540) (780.590, 806.820)
False : No      Layer : M2     Bounds (780.310, 825.580) (780.590, 825.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1287 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 812.140) (763.430, 812.420)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 6
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1288 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1186
False : No      Layer : M2     Bounds (746.650, 752.780) (746.930, 753.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1294 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2106
False : No      Layer : M2     Bounds (745.280, 816.060) (745.660, 816.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1333 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2097
False : No      Layer : M2     Bounds (762.440, 781.340) (762.820, 781.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1341 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1198
False : No      Layer : M2     Bounds (728.830, 822.780) (729.110, 823.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1341 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1244
False : No      Layer : M2     Bounds (730.150, 822.780) (730.430, 823.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1360 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802
False : No      Layer : M2     Bounds (761.830, 797.580) (762.110, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1384 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[11]
False : No      Layer : M2     Bounds (777.010, 811.580) (777.290, 811.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1410 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 830.620) (763.430, 830.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1410 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802
False : No      Layer : M2     Bounds (761.830, 830.620) (762.110, 830.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1436 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[16]
False : No      Layer : M2     Bounds (800.110, 822.220) (800.390, 822.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1650 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[27]
False : No      Layer : M2     Bounds (840.370, 798.140) (840.650, 801.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1650 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[27]
False : No      Layer : M2     Bounds (841.030, 801.500) (841.310, 801.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[14]
False : No      Layer : M2     Bounds (782.950, 806.540) (783.230, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[7]
False : No      Layer : M2     Bounds (765.130, 735.980) (765.410, 736.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1727 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1160
False : No      Layer : M2     Bounds (762.490, 740.460) (762.770, 740.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1727 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1299
False : No      Layer : M2     Bounds (796.810, 821.100) (797.090, 821.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1738 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1972
False : No      Layer : M2     Bounds (720.910, 654.780) (721.190, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1771 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1223
False : No      Layer : M2     Bounds (763.760, 825.580) (764.140, 825.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1771 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1286
False : No      Layer : M2     Bounds (778.990, 826.140) (779.270, 826.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1771 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933
False : No      Layer : M2     Bounds (772.390, 826.140) (772.670, 826.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1772 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_943
False : No      Layer : M2     Bounds (755.230, 815.500) (755.510, 815.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1771
False : No      Layer : M2     Bounds (763.810, 822.780) (764.090, 823.060)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 7
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1776 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 799.820) (763.430, 800.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1776 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802
False : No      Layer : M2     Bounds (761.830, 799.820) (762.110, 800.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1777 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_943
False : No      Layer : M2     Bounds (755.230, 771.820) (755.510, 772.100)
False : No      Layer : M2     Bounds (755.230, 782.460) (755.510, 782.740)
False : No      Layer : M2     Bounds (755.230, 791.980) (755.510, 792.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1778 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1776
False : No      Layer : M2     Bounds (757.870, 792.540) (758.150, 792.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1780 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2049
False : No      Layer : M2     Bounds (755.890, 742.140) (756.170, 742.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1780 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7]
False : No      Layer : M2     Bounds (756.500, 744.940) (756.880, 745.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1785 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090
False : No      Layer : M2     Bounds (720.250, 704.620) (720.530, 704.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1786 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1213
False : No      Layer : M2     Bounds (738.730, 705.740) (739.010, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1789 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1788
False : No      Layer : M2     Bounds (728.830, 694.540) (729.110, 694.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1789 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794
False : No      Layer : M2     Bounds (729.490, 690.060) (729.770, 690.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1790 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2029
False : No      Layer : M2     Bounds (737.410, 721.980) (737.690, 722.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1792 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1970
False : No      Layer : M2     Bounds (709.690, 658.700) (709.970, 658.980)
False : No      Layer : M2     Bounds (710.350, 661.500) (710.630, 661.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1792 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 658.700) (709.310, 658.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1789
False : No      Layer : M2     Bounds (728.170, 691.180) (728.450, 691.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1792
False : No      Layer : M2     Bounds (703.040, 671.020) (703.420, 671.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1797
False : No      Layer : M2     Bounds (728.170, 664.860) (728.450, 665.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2013
False : No      Layer : M2     Bounds (729.490, 689.500) (729.770, 689.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1795 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716
False : No      Layer : M2     Bounds (720.250, 630.700) (720.530, 630.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1795 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1972
False : No      Layer : M2     Bounds (720.910, 660.380) (721.190, 660.660)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 8
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1798 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1045
False : No      Layer : M2     Bounds (736.750, 690.060) (737.030, 690.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1798 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1137
False : No      Layer : M2     Bounds (736.090, 690.060) (736.370, 690.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1798 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794
False : No      Layer : M2     Bounds (728.780, 691.180) (729.770, 691.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1800 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_937
False : No      Layer : M2     Bounds (736.750, 746.620) (737.030, 746.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1800 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 746.620) (736.370, 746.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 831.740) (763.430, 832.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1776
False : No      Layer : M2     Bounds (761.170, 796.460) (761.450, 796.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1853 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147
False : No      Layer : M2     Bounds (710.300, 802.060) (710.680, 802.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1855 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1193
False : No      Layer : M2     Bounds (719.590, 826.700) (720.530, 826.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1855 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_904
False : No      Layer : M2     Bounds (718.880, 831.740) (720.530, 832.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1857 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (697.810, 740.460) (698.090, 745.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1857 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (697.150, 740.460) (697.430, 740.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1859 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862
False : No      Layer : M2     Bounds (685.930, 730.380) (686.210, 730.660)
False : No      Layer : M2     Bounds (687.250, 732.060) (687.530, 732.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1219
False : No      Layer : M2     Bounds (685.930, 730.940) (686.210, 731.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870
False : No      Layer : M2     Bounds (685.930, 716.380) (686.210, 716.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1867 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1865
False : No      Layer : M2     Bounds (675.370, 669.340) (675.650, 669.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1868 & Regular Wire of Net scan_clkI
False : No      Layer : M2     Bounds (672.730, 650.860) (673.010, 651.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 680.540) (687.530, 680.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 716.380) (687.530, 716.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1873 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3092
False : No      Layer : M2     Bounds (696.490, 771.820) (696.770, 772.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1885 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[3]
False : No      Layer : M2     Bounds (718.880, 765.660) (719.260, 765.940)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 9
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1888 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (720.910, 781.340) (721.190, 782.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1891 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1888
False : No      Layer : M2     Bounds (728.830, 780.220) (729.110, 780.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1917 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_999
False : No      Layer : M2     Bounds (693.850, 640.780) (694.130, 641.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1919 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (720.860, 776.300) (721.190, 776.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1919 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (720.910, 775.740) (721.190, 776.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053
False : No      Layer : M2     Bounds (686.590, 701.260) (687.530, 701.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1096
False : No      Layer : M2     Bounds (686.540, 660.940) (687.530, 661.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1198
False : No      Layer : M2     Bounds (736.700, 827.260) (737.080, 827.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 691.180) (687.530, 691.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1957 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060
False : No      Layer : M2     Bounds (746.650, 654.780) (746.930, 660.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1961 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[0]
False : No      Layer : M2     Bounds (710.350, 645.820) (710.630, 646.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1961 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 645.820) (709.310, 646.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1970 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1961
False : No      Layer : M2     Bounds (709.640, 645.820) (710.020, 646.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1972 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_856
False : No      Layer : M2     Bounds (720.250, 671.580) (720.530, 671.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1974 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[2]
False : No      Layer : M2     Bounds (693.190, 651.420) (693.470, 651.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1975 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/FE_OFN9_n_868
False : No      Layer : M2     Bounds (697.150, 644.700) (697.430, 644.980)
False : No      Layer : M2     Bounds (697.150, 651.420) (697.430, 651.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1976 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2003
False : No      Layer : M2     Bounds (670.090, 711.900) (670.370, 712.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1979 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072
False : No      Layer : M2     Bounds (686.590, 659.820) (686.870, 660.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1979 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 659.820) (687.530, 660.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1979 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063
False : No      Layer : M2     Bounds (687.910, 659.820) (688.190, 660.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1986 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 696.220) (709.310, 696.500)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 10
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1988 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870
False : No      Layer : M2     Bounds (686.590, 680.540) (686.870, 680.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1988 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.200, 685.580) (687.580, 685.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1995 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1797
False : No      Layer : M2     Bounds (738.070, 685.020) (738.350, 685.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1995 & Special Via of Net VDD
False : No      Layer : M2     Bounds (744.010, 687.840) (744.290, 688.640)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1997 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1045
False : No      Layer : M2     Bounds (720.250, 686.140) (720.530, 686.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1998 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1997
False : No      Layer : M2     Bounds (720.910, 676.060) (721.190, 676.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2001 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1048
False : No      Layer : M2     Bounds (711.670, 701.820) (711.950, 702.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2004 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1976
False : No      Layer : M2     Bounds (670.700, 711.900) (671.030, 712.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2005 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053
False : No      Layer : M2     Bounds (686.590, 705.740) (686.870, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2005 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 705.740) (687.530, 706.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2017 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2108
False : No      Layer : M2     Bounds (725.530, 805.980) (725.810, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2017 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9]
False : No      Layer : M2     Bounds (726.190, 805.980) (726.520, 806.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2021 & Special Via of Net VDD
False : No      Layer : M2     Bounds (694.510, 718.080) (694.790, 718.880)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2039 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1976
False : No      Layer : M2     Bounds (670.040, 715.260) (671.030, 715.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2039 & Regular Wire of Net scan_clkI
False : No      Layer : M2     Bounds (672.730, 741.580) (673.010, 741.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2049 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3076
False : No      Layer : M2     Bounds (755.180, 730.940) (755.560, 731.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2061 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1238
False : No      Layer : M2     Bounds (745.330, 724.780) (745.610, 725.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2061 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1288
False : No      Layer : M2     Bounds (747.310, 752.780) (747.590, 761.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2061 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2098
False : No      Layer : M2     Bounds (745.990, 761.740) (746.270, 762.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2067 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2038
False : No      Layer : M2     Bounds (682.630, 741.020) (682.910, 741.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2079 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1172
False : No      Layer : M2     Bounds (747.310, 781.340) (747.590, 782.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2085 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1193
False : No      Layer : M2     Bounds (738.730, 802.620) (739.010, 802.900)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 11
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2085 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1891
False : No      Layer : M2     Bounds (734.770, 795.900) (735.050, 796.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2085 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 795.900) (736.370, 796.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2087 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2103
False : No      Layer : M2     Bounds (727.510, 812.140) (727.790, 812.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2094 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1183
False : No      Layer : M2     Bounds (748.580, 781.340) (748.960, 781.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2097 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_943
False : No      Layer : M2     Bounds (755.230, 772.380) (755.510, 772.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2098 & Special Via of Net VDD
False : No      Layer : M2     Bounds (743.350, 768.480) (743.630, 769.280)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2103 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147
False : No      Layer : M2     Bounds (709.030, 791.980) (709.310, 792.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2103 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1873
False : No      Layer : M2     Bounds (709.690, 791.980) (709.970, 792.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2103 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[8]
False : No      Layer : M2     Bounds (710.350, 791.980) (710.630, 792.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2116 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 826.700) (763.430, 826.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2116 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802
False : No      Layer : M2     Bounds (761.830, 826.700) (762.110, 826.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2126 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933
False : No      Layer : M2     Bounds (786.910, 816.060) (787.190, 816.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2126 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[12]
False : No      Layer : M2     Bounds (773.050, 816.620) (773.330, 816.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2128 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1237
False : No      Layer : M2     Bounds (766.450, 811.580) (766.730, 811.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2128 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933
False : No      Layer : M2     Bounds (765.790, 807.100) (766.070, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2163 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1286
False : No      Layer : M2     Bounds (778.990, 807.100) (779.270, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2163 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[11]
False : No      Layer : M2     Bounds (779.650, 807.100) (779.930, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2163 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[13]
False : No      Layer : M2     Bounds (780.310, 807.100) (780.590, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2180 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1299
False : No      Layer : M2     Bounds (796.810, 821.660) (797.090, 823.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2180 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1727
False : No      Layer : M2     Bounds (796.100, 821.660) (796.480, 821.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[14]
False : No      Layer : M2     Bounds (811.990, 817.180) (812.270, 817.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[5]
False : No      Layer : M2     Bounds (758.530, 639.100) (758.810, 639.380)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 12
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1137
False : No      Layer : M2     Bounds (736.090, 676.060) (736.370, 676.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1162
False : No      Layer : M2     Bounds (728.780, 705.180) (729.160, 705.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (687.250, 690.620) (687.530, 690.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946
False : No      Layer : M2     Bounds (685.880, 690.620) (686.260, 690.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2019
False : No      Layer : M2     Bounds (728.170, 741.020) (728.450, 741.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3065 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1972
False : No      Layer : M2     Bounds (720.910, 664.860) (721.190, 665.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1891
False : No      Layer : M2     Bounds (734.770, 827.260) (735.050, 827.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[9]
False : No      Layer : M2     Bounds (740.050, 807.100) (740.330, 807.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3074 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2028
False : No      Layer : M2     Bounds (748.630, 721.420) (748.910, 721.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3075 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1971
False : No      Layer : M2     Bounds (711.670, 669.900) (711.950, 670.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3076 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[8]
False : No      Layer : M2     Bounds (763.150, 725.900) (763.430, 726.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3083 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072
False : No      Layer : M2     Bounds (681.970, 640.220) (682.250, 640.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3083 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (685.270, 654.780) (685.550, 658.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3083 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (685.270, 654.780) (685.600, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3084 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (680.650, 664.860) (680.980, 665.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1869
False : No      Layer : M2     Bounds (680.650, 680.540) (680.930, 680.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (681.310, 664.860) (681.590, 665.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3095 & Regular Wire of Net DTMF_INST/spi_clk
False : No      Layer : M2     Bounds (770.410, 735.980) (770.690, 736.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_856 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1997
False : No      Layer : M2     Bounds (720.200, 674.940) (720.580, 675.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_857 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1794
False : No      Layer : M2     Bounds (729.490, 665.420) (729.770, 665.700)
False : No      Layer : M2     Bounds (729.490, 685.020) (729.770, 685.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_861 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1089
False : No      Layer : M2     Bounds (740.050, 706.300) (740.330, 706.580)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 13
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_861 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090
False : No      Layer : M2     Bounds (739.390, 706.300) (739.670, 706.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_904 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1193
False : No      Layer : M2     Bounds (719.590, 812.700) (719.870, 812.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1113
False : No      Layer : M2     Bounds (746.650, 671.020) (747.590, 671.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1132
False : No      Layer : M2     Bounds (755.180, 695.100) (755.560, 695.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1183
False : No      Layer : M2     Bounds (746.650, 755.580) (746.980, 755.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1957
False : No      Layer : M2     Bounds (746.650, 660.940) (746.930, 661.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060
False : No      Layer : M2     Bounds (746.650, 640.780) (746.930, 641.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[2]
False : No      Layer : M2     Bounds (747.310, 634.620) (747.590, 636.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1773
False : No      Layer : M2     Bounds (763.150, 822.780) (763.480, 823.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[11]
False : No      Layer : M2     Bounds (779.650, 805.980) (779.930, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_933 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[12]
False : No      Layer : M2     Bounds (773.050, 826.140) (773.330, 826.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_935 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1359
False : No      Layer : M2     Bounds (765.740, 790.860) (766.120, 791.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_935 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1782
False : No      Layer : M2     Bounds (756.550, 776.300) (756.830, 776.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_937 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1186
False : No      Layer : M2     Bounds (746.600, 751.660) (746.930, 751.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_942 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1789
False : No      Layer : M2     Bounds (729.440, 694.540) (729.820, 694.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_978 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085
False : No      Layer : M2     Bounds (745.940, 664.300) (746.320, 664.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_988 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085
False : No      Layer : M2     Bounds (681.310, 636.300) (681.590, 636.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_999 & Special Via of Net VDD
False : No      Layer : M2     Bounds (693.850, 637.440) (694.130, 638.240)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[4] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[1]
False : No      Layer : M2     Bounds (753.250, 636.300) (753.530, 636.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[4] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[7]
False : No      Layer : M2     Bounds (764.470, 660.380) (764.750, 660.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[7] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1995
False : No      Layer : M2     Bounds (744.010, 683.900) (744.290, 684.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[0] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068
False : No      Layer : M2     Bounds (739.390, 781.900) (739.670, 782.180)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 14
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1150
False : No      Layer : M2     Bounds (737.410, 781.340) (737.690, 781.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[0]
False : No      Layer : M2     Bounds (736.090, 640.220) (736.370, 640.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[1]
False : No      Layer : M2     Bounds (685.930, 654.780) (686.260, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (696.440, 735.420) (697.430, 735.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[2] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1917
False : No      Layer : M2     Bounds (729.490, 635.180) (729.770, 635.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[10] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[10]
False : No      Layer : M2     Bounds (783.610, 771.260) (783.890, 771.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[14] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[13]
False : No      Layer : M2     Bounds (805.340, 801.500) (805.720, 801.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[15] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060
False : No      Layer : M2     Bounds (818.590, 817.740) (818.870, 818.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[15] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[18]
False : No      Layer : M2     Bounds (819.250, 817.740) (819.530, 818.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[16] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[15]
False : No      Layer : M2     Bounds (819.910, 806.540) (820.190, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[2] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060
False : No      Layer : M2     Bounds (746.650, 636.300) (746.930, 636.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[6] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[4]
False : No      Layer : M2     Bounds (754.570, 670.460) (754.850, 670.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060
False : No      Layer : M2     Bounds (747.970, 757.260) (748.250, 757.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/dp & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (827.780, 630.140) (828.160, 630.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[11] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[11]
False : No      Layer : M2     Bounds (788.840, 705.180) (789.220, 705.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[12] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[14]
False : No      Layer : M2     Bounds (767.110, 565.180) (767.390, 565.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[14] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[15]
False : No      Layer : M2     Bounds (767.060, 560.140) (767.440, 560.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[6] & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (772.390, 630.140) (772.670, 630.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[10] & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (780.970, 766.220) (783.890, 766.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[11] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[13]
False : No      Layer : M2     Bounds (780.310, 776.300) (780.590, 776.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[13] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[13]
False : No      Layer : M2     Bounds (806.710, 795.900) (806.990, 796.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[13] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[14]
False : No      Layer : M2     Bounds (837.070, 695.100) (838.060, 695.380)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 15
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[15] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[18]
False : No      Layer : M2     Bounds (819.250, 776.300) (819.530, 776.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[3] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[3]
False : No      Layer : M2     Bounds (779.650, 660.940) (779.930, 661.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[3] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[4]
False : No      Layer : M2     Bounds (778.330, 650.860) (778.610, 651.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[18] & Regular Wire of Net scan_enI
False : No      Layer : M2     Bounds (647.650, 734.860) (647.930, 735.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[0] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716
False : No      Layer : M2     Bounds (720.250, 646.940) (720.530, 647.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[11] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1268
False : No      Layer : M2     Bounds (731.470, 831.740) (731.750, 832.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[11] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1802
False : No      Layer : M2     Bounds (761.830, 818.300) (762.110, 818.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[12] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[12]
False : No      Layer : M2     Bounds (771.680, 831.740) (773.330, 832.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072
False : No      Layer : M2     Bounds (686.590, 654.780) (686.870, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1866
False : No      Layer : M2     Bounds (674.050, 660.380) (674.330, 660.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_986
False : No      Layer : M2     Bounds (703.700, 644.700) (704.080, 644.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[27] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1650
False : No      Layer : M2     Bounds (840.370, 801.500) (840.700, 801.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[27] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (840.370, 791.420) (840.700, 791.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[2] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[1]
False : No      Layer : M2     Bounds (710.350, 781.340) (710.630, 781.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[2] & Special Via of Net VDD
False : No      Layer : M2     Bounds (693.190, 657.600) (693.470, 658.400)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[31] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1970
False : No      Layer : M2     Bounds (709.690, 655.900) (709.970, 656.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[31] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[0]
False : No      Layer : M2     Bounds (710.350, 645.260) (710.630, 645.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[31] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6]
False : No      Layer : M2     Bounds (720.910, 761.740) (721.190, 762.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[3] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1026
False : No      Layer : M2     Bounds (702.430, 691.740) (702.710, 692.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[3] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 711.340) (709.310, 711.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[4] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862
False : No      Layer : M2     Bounds (685.930, 710.780) (686.210, 711.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[4] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942
False : No      Layer : M2     Bounds (755.230, 655.900) (755.510, 656.180)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 16
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[5] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1070
False : No      Layer : M2     Bounds (728.830, 755.580) (729.110, 755.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[5] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2019
False : No      Layer : M2     Bounds (728.170, 744.940) (729.160, 745.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[7] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 755.580) (736.370, 755.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[7] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[7]
False : No      Layer : M2     Bounds (703.750, 791.420) (704.030, 791.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[8] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1891
False : No      Layer : M2     Bounds (734.770, 785.820) (735.050, 786.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[8] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 771.820) (736.370, 772.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2017
False : No      Layer : M2     Bounds (728.170, 811.580) (728.450, 811.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2087
False : No      Layer : M2     Bounds (726.850, 805.980) (727.130, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068
False : No      Layer : M2     Bounds (739.390, 791.980) (739.670, 792.260)
False : No      Layer : M2     Bounds (739.390, 802.620) (739.670, 802.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (736.090, 811.580) (736.420, 811.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[0] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907
False : No      Layer : M2     Bounds (747.310, 664.860) (747.590, 665.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[10] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_935
False : No      Layer : M2     Bounds (757.210, 785.820) (757.490, 786.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[10] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[11]
False : No      Layer : M2     Bounds (788.230, 719.740) (788.510, 720.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[10] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[11]
False : No      Layer : M2     Bounds (703.700, 821.660) (704.080, 821.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[11] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_943
False : No      Layer : M2     Bounds (755.230, 816.620) (755.510, 816.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[14] & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (782.950, 776.300) (783.230, 776.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[18] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[16]
False : No      Layer : M2     Bounds (819.250, 806.540) (819.530, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[1] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[31]
False : No      Layer : M2     Bounds (709.030, 665.420) (709.310, 665.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[24] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1]
False : No      Layer : M2     Bounds (840.370, 774.620) (840.650, 782.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[2] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946
False : No      Layer : M2     Bounds (683.900, 664.860) (684.280, 665.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[2] & Regular Wire of Net scan_clkI
False : No      Layer : M2     Bounds (672.730, 786.380) (673.010, 786.660)
*********** SOC ENCOUNTER Violation Browser Report **********
Report File Name :  DTMF_CHIP.viols.rpt        Page : 17
False : No      Layer : M2     Bounds (672.730, 789.740) (673.010, 790.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[3] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946
False : No      Layer : M2     Bounds (686.540, 691.180) (686.920, 691.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[4] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053
False : No      Layer : M2     Bounds (686.590, 711.340) (686.870, 711.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[5] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[9]
False : No      Layer : M2     Bounds (697.810, 799.260) (698.090, 802.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[6] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2061
False : No      Layer : M2     Bounds (747.310, 730.940) (747.590, 731.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[6] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[7]
False : No      Layer : M2     Bounds (703.750, 786.380) (704.030, 786.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[6] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[9]
False : No      Layer : M2     Bounds (697.100, 795.900) (697.480, 796.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[3]
False : No      Layer : M2     Bounds (702.430, 805.980) (702.710, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[4]
False : No      Layer : M2     Bounds (703.090, 805.980) (703.370, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_943
False : No      Layer : M2     Bounds (755.230, 781.340) (755.510, 781.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[9]
False : No      Layer : M2     Bounds (740.050, 802.060) (740.330, 802.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[0] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 670.460) (647.320, 670.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[15] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 725.900) (647.320, 726.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[16] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 720.860) (647.320, 721.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[19] & Regular Wire of Net scan_enI
False : No      Layer : M2     Bounds (654.250, 734.300) (654.530, 734.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[20] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 741.020) (647.320, 741.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[21] & Regular Via of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (654.200, 751.100) (654.580, 751.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[24] & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (667.450, 764.540) (667.730, 764.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[27] & Special Via of Net VDD
False : No      Layer : M2     Bounds (691.870, 778.560) (692.150, 779.360)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[2] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 680.540) (647.320, 680.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[5] & Regular Wire of Net scan_enI
False : No      Layer : M2     Bounds (647.650, 700.700) (647.930, 700.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[8] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1861
False : No      Layer : M2     Bounds (666.130, 693.980) (666.410, 694.260)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 18
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[9] & Regular Via of Net scan_enI
False : No      Layer : M2     Bounds (646.940, 705.740) (647.320, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/sel_op_a[1] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/sel_op_a[2]
False : No      Layer : M2     Bounds (817.880, 644.700) (818.260, 644.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[10] & Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI
False : No      Layer : M2     Bounds (781.580, 776.300) (781.960, 776.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[4] & Regular Wire of Net DTMF_INST/spi_clk
False : No      Layer : M2     Bounds (770.410, 623.420) (770.690, 623.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[5] & Regular Wire of Net DTMF_INST/spi_clk
False : No      Layer : M2     Bounds (770.410, 640.780) (770.690, 641.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[6] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[6]
False : No      Layer : M2     Bounds (772.390, 655.340) (772.670, 655.620)
False : No      Layer : M2     Bounds (772.390, 660.940) (772.670, 661.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[8] & Regular Wire of Net DTMF_INST/spi_clk
False : No      Layer : M2     Bounds (770.410, 751.100) (770.690, 751.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[9] & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[14]
False : No      Layer : M2     Bounds (782.950, 752.780) (783.230, 753.060)
Regular Via of Net DTMF_INST/clk & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (654.200, 500.800) (654.580, 501.080)
Regular Via of Net DTMF_INST/m_clk__L8_N0 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[10]
False : No      Layer : M2     Bounds (788.890, 771.820) (789.170, 772.100)
Regular Via of Net DTMF_INST/m_clk__L8_N1 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[0]
False : No      Layer : M2     Bounds (764.470, 630.700) (764.750, 630.980)
Regular Via of Net DTMF_INST/m_clk__L8_N1 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[11]
False : No      Layer : M2     Bounds (777.010, 751.660) (777.290, 751.940)
Regular Via of Net DTMF_INST/spi_clk & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (654.200, 540.800) (654.580, 541.080)
Regular Via of Net ibiasI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (355.580, 540.540) (355.600, 541.080)
Regular Via of Net ibiasI & Special Wire of Net VSS
False : No      Layer : M2     Bounds (355.220, 540.540) (355.270, 541.080)
Regular Via of Net pllrstI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (355.580, 380.800) (355.600, 381.220)
Regular Via of Net pllrstI & Special Wire of Net VSS
False : No      Layer : M2     Bounds (355.220, 380.800) (355.270, 381.220)
Regular Via of Net refclkI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (355.580, 500.780) (355.600, 501.080)
Regular Via of Net refclkI & Special Wire of Net VSS
False : No      Layer : M2     Bounds (355.220, 500.780) (355.270, 501.080)
Regular Via of Net vcomO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (355.580, 420.700) (355.600, 421.080)
Regular Via of Net vcomO & Special Wire of Net VSS
False : No      Layer : M2     Bounds (355.220, 420.700) (355.270, 421.080)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 19
Regular Via of Net vcopO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M2     Bounds (355.580, 460.800) (355.600, 461.300)
Regular Wire of Net vcopO & Blockage of Cell IOPADS_INST/Pavss0
False : No      Layer : M2     Bounds (234.490, 537.600) (234.770, 542.355)
Regular Wire of Net vcopO & Pin of Cell IOPADS_INST/Pavss0
False : No      Layer : M2     Bounds (234.490, 542.955) (234.770, 572.245)
False : No      Layer : M2     Bounds (234.490, 572.845) (234.770, 577.600)
Regular Wire of Net vcopO & Blockage of Cell IOPADS_INST/Pibiasip
False : No      Layer : M2     Bounds (234.490, 606.115) (234.770, 611.665)
Regular Wire of Net vcopO & Pin of Cell IOPADS_INST/Pibiasip
False : No      Layer : M2     Bounds (234.490, 611.945) (234.770, 613.945)
False : No      Layer : M2     Bounds (234.490, 614.225) (234.770, 646.115)
Regular Wire of Net vcopO & Blockage of Cell IOPADS_INST/Pvcomop
False : No      Layer : M2     Bounds (234.490, 674.630) (234.770, 680.180)
Regular Wire of Net vcopO & Pin of Cell IOPADS_INST/Pvcomop
False : No      Layer : M2     Bounds (234.490, 680.460) (234.770, 682.460)
False : No      Layer : M2     Bounds (234.490, 682.740) (234.770, 714.630)
Regular Wire of Net vcopO & Blockage of Cell IOPADS_INST/Pvcopop
False : No      Layer : M2     Bounds (234.490, 743.145) (234.770, 748.695)
Regular Wire of Net vcopO & Blockage of Cell IOPADS_INST/Pvss2
False : No      Layer : M2     Bounds (234.490, 469.080) (234.770, 473.835)
Regular Wire of Net vcopO & Pin of Cell IOPADS_INST/Pvss2
False : No      Layer : M2     Bounds (234.490, 474.435) (234.770, 503.725)
False : No      Layer : M2     Bounds (234.490, 504.325) (234.770, 509.080)
Regular Via of Net vcopO & Special Wire of Net VSS
False : No      Layer : M2     Bounds (355.220, 460.800) (355.270, 461.300)
Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 762.860) (693.520, 763.140)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 770.700) (692.860, 770.980)
False : No      Layer : M3     Bounds (741.980, 620.060) (746.280, 620.340)
False : No      Layer : M3     Bounds (741.980, 643.020) (743.680, 643.300)
False : No      Layer : M3     Bounds (744.620, 629.580) (746.280, 629.860)
Regular Via of Net DTMF_INST/FE_OFN0_scan_enI & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 609.980) (737.740, 610.260)
Regular Wire of Net DTMF_INST/FE_OFN0_scan_enI & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 606.060) (740.280, 606.340)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 20
False : No      Layer : M3     Bounds (785.280, 625.100) (788.560, 625.380)
False : No      Layer : M3     Bounds (785.280, 670.460) (785.920, 670.740)
False : No      Layer : M3     Bounds (786.200, 806.540) (787.240, 806.820)
False : No      Layer : M3     Bounds (787.520, 635.180) (788.560, 635.460)
False : No      Layer : M3     Bounds (839.000, 647.500) (840.040, 647.780)
Regular Via of Net DTMF_INST/FE_OFN5_scan_enI & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 806.540) (842.680, 806.820)
Regular Wire of Net DTMF_INST/FE_OFN5_scan_enI & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.680, 815.500) (840.040, 815.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/FE_OFN9_n_868 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 822.780) (741.700, 823.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/FE_OFN9_n_868 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.380, 792.540) (737.740, 792.820)
False : No      Layer : M3     Bounds (738.680, 772.380) (739.060, 772.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1020 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 644.140) (694.840, 644.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1023 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 634.620) (746.280, 634.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1032 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 660.380) (737.080, 660.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1033 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 677.740) (696.280, 678.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1033 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.200, 676.620) (688.240, 676.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1042 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 640.780) (745.660, 641.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1042 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 663.740) (740.280, 664.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1045 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 688.380) (737.080, 688.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1053 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 701.820) (686.920, 702.100)
False : No      Layer : M3     Bounds (685.280, 715.260) (686.920, 715.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1056 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 677.180) (746.280, 677.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1056 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 676.620) (740.280, 676.900)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 21
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1057 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 694.540) (695.500, 694.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1063 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (694.460, 699.020) (694.840, 699.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1066 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.960, 660.940) (744.340, 661.220)
False : No      Layer : M3     Bounds (744.620, 678.860) (746.280, 679.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1072 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 640.780) (686.920, 641.060)
False : No      Layer : M3     Bounds (685.280, 657.580) (686.920, 657.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1073 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 711.900) (696.280, 712.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1089 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 700.700) (740.280, 700.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 714.700) (743.680, 714.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 704.620) (739.720, 704.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1090 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (739.340, 714.700) (740.280, 714.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1095 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 721.980) (694.180, 722.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1095 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 725.900) (687.580, 726.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1096 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 660.940) (686.260, 661.220)
False : No      Layer : M3     Bounds (685.280, 671.020) (686.260, 671.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1097 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 685.580) (694.180, 685.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1097 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 714.140) (686.920, 714.420)
False : No      Layer : M3     Bounds (686.540, 685.020) (688.240, 685.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1100 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 741.580) (694.840, 741.860)
False : No      Layer : M3     Bounds (695.120, 731.500) (696.280, 731.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1100 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.200, 728.140) (688.240, 728.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1103 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 702.380) (746.280, 702.660)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 22
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1116 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 757.820) (739.720, 758.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1135 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 745.500) (743.680, 745.780)
False : No      Layer : M3     Bounds (744.620, 734.860) (746.280, 735.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1135 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 745.500) (737.740, 745.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1135 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 732.060) (739.060, 732.340)
False : No      Layer : M3     Bounds (738.020, 742.140) (738.400, 742.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1137 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 715.260) (743.020, 715.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1137 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 676.620) (736.420, 676.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1137 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.040, 713.580) (737.740, 713.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1144 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.780, 751.660) (696.280, 751.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1147 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 777.420) (736.420, 777.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1150 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 785.260) (739.060, 785.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1151 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 771.260) (738.400, 771.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1162 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 734.300) (735.760, 734.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1167 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (694.460, 771.820) (694.840, 772.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1168 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 711.900) (694.180, 712.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1170 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 797.580) (735.760, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1173 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 805.980) (739.720, 806.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1186 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 771.260) (746.280, 771.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1187 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (742.640, 701.260) (743.020, 701.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1187 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 750.540) (746.280, 750.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1193 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 805.420) (739.060, 805.700)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 23
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1197 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 818.300) (746.280, 818.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1198 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 825.580) (737.740, 825.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1201 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 826.140) (735.760, 826.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1202 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 817.740) (744.340, 818.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1202 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (740.000, 817.740) (740.280, 818.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1213 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 707.420) (740.280, 707.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1218 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (686.540, 739.340) (687.580, 739.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1223 & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062
False : No      Layer : M3     Bounds (757.160, 827.260) (757.540, 827.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1238 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 725.900) (746.280, 726.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1239 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.960, 724.220) (746.280, 724.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1245 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.880, 769.020) (688.240, 769.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1251 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 808.220) (787.900, 808.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1262 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 813.260) (790.280, 813.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1264 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (742.640, 777.980) (744.340, 778.260)
False : No      Layer : M3     Bounds (745.280, 786.380) (745.660, 786.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1264 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 747.180) (740.280, 747.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1283 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 812.140) (795.820, 812.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1286 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 816.060) (788.560, 816.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1294 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 816.060) (745.660, 816.340)
False : No      Layer : M3     Bounds (745.280, 821.660) (745.660, 821.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1310 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907
False : No      Layer : M3     Bounds (810.620, 816.060) (811.660, 816.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1334 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 817.180) (787.900, 817.460)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 24
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1385 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (793.460, 831.740) (793.840, 832.020)
False : No      Layer : M3     Bounds (794.780, 817.740) (795.820, 818.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1435 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.780, 826.700) (795.160, 826.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1435 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 817.740) (790.280, 818.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1436 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 827.820) (796.280, 828.100)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1448 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 830.620) (846.280, 830.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1650 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 798.140) (843.340, 798.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.980, 700.700) (743.680, 700.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 776.300) (743.680, 776.580)
False : No      Layer : M3     Bounds (744.620, 796.460) (746.280, 796.740)
False : No      Layer : M3     Bounds (795.440, 816.620) (796.280, 816.900)
False : No      Layer : M3     Bounds (841.280, 831.740) (843.340, 832.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1716 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 675.500) (737.740, 675.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1727 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 821.660) (796.280, 821.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1727 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.840, 819.420) (790.280, 819.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1738 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.940, 784.700) (746.280, 784.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1738 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 635.180) (735.760, 635.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1738 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 684.460) (740.280, 684.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1785 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 721.420) (743.680, 721.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1785 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 711.340) (737.740, 711.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1786 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (742.640, 719.740) (744.340, 720.020)
False : No      Layer : M3     Bounds (742.640, 746.060) (744.340, 746.340)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 25
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1786 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 705.740) (740.280, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1787 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 695.100) (743.020, 695.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1787 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 695.100) (740.280, 695.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1790 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 718.620) (736.420, 718.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1793 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 671.020) (696.280, 671.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1797 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 672.700) (738.400, 672.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1798 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 690.620) (735.760, 690.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1799 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 705.740) (737.740, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1800 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 744.380) (737.080, 744.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1857 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 746.620) (696.280, 746.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1858 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 727.020) (692.860, 727.300)
False : No      Layer : M3     Bounds (691.820, 739.340) (694.180, 739.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1859 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 739.900) (696.160, 740.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1859 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.200, 738.780) (688.240, 739.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1861 & Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[3]
False : No      Layer : M3     Bounds (668.720, 700.140) (669.760, 700.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1862 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 706.860) (686.260, 707.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1863 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 771.260) (696.280, 771.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1863 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.200, 728.700) (688.240, 728.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1869 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 671.580) (685.600, 671.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1870 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 674.380) (685.600, 674.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1915 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 643.580) (694.840, 643.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1917 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.140, 640.780) (694.840, 641.060)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 26
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1917 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 748.300) (786.580, 748.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1918 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (786.200, 752.220) (787.240, 752.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 685.020) (693.520, 685.300)
False : No      Layer : M3     Bounds (693.800, 731.500) (694.840, 731.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.200, 651.980) (688.240, 652.260)
False : No      Layer : M3     Bounds (687.200, 685.580) (688.240, 685.860)
False : No      Layer : M3     Bounds (687.200, 718.620) (688.240, 718.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1942 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 648.060) (735.760, 648.340)
False : No      Layer : M3     Bounds (735.280, 776.300) (737.080, 776.580)
False : No      Layer : M3     Bounds (735.280, 824.460) (737.080, 824.740)
False : No      Layer : M3     Bounds (738.020, 807.100) (738.400, 807.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1944 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 646.380) (737.740, 646.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 704.620) (694.180, 704.900)
False : No      Layer : M3     Bounds (693.140, 735.420) (694.180, 735.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.880, 690.620) (687.580, 690.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1946 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (688.520, 654.780) (689.560, 655.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1955 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 655.340) (740.280, 655.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1957 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 654.780) (746.280, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1962 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 641.900) (696.280, 642.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1965 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 650.300) (686.260, 650.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1966 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 635.740) (693.520, 636.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1966 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.880, 637.420) (688.240, 637.700)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 27
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1968 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 633.500) (694.840, 633.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1974 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 653.660) (694.840, 653.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1979 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 660.380) (686.260, 660.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1980 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (689.840, 652.540) (690.220, 652.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1984 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 667.100) (736.420, 667.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1994 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 666.540) (737.740, 666.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1995 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 685.020) (744.340, 685.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_1995 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 685.020) (740.280, 685.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2005 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 701.260) (686.260, 701.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2011 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 681.100) (745.660, 681.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2011 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.380, 682.780) (737.740, 683.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2020 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 711.340) (693.520, 711.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2021 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (694.460, 712.460) (694.840, 712.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2029 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 713.020) (738.400, 713.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2051 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 760.620) (738.400, 760.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2052 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 752.220) (737.740, 752.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2062 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 715.820) (744.340, 716.100)
False : No      Layer : M3     Bounds (741.320, 751.660) (744.340, 751.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2062 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 732.060) (737.740, 732.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2062 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 723.660) (739.060, 723.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2066 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 749.980) (696.280, 750.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2066 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 750.540) (688.240, 750.820)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 28
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2071 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 773.500) (737.080, 773.780)
False : No      Layer : M3     Bounds (736.700, 789.740) (737.080, 790.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2071 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (739.340, 822.780) (740.280, 823.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2080 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 744.380) (746.280, 744.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2080 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 735.420) (740.280, 735.700)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2085 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 802.620) (739.060, 802.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2098 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 762.300) (746.280, 762.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2102 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 820.540) (735.760, 820.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2106 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 817.180) (746.280, 817.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2106 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 815.500) (740.280, 815.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2126 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 816.620) (787.240, 816.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2142 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 811.580) (788.560, 811.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2161 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 823.340) (795.160, 823.620)
False : No      Layer : M3     Bounds (794.120, 830.060) (795.160, 830.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2162 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (792.800, 826.700) (793.840, 826.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2193 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 827.260) (796.280, 827.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2194 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.480, 826.140) (793.180, 826.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_2194 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (789.500, 816.620) (790.280, 816.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 659.820) (746.280, 660.100)
False : No      Layer : M3     Bounds (796.100, 811.020) (796.280, 811.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3060 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 831.180) (836.080, 831.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 700.140) (742.360, 700.420)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 29
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.980, 776.860) (742.360, 777.140)
False : No      Layer : M3     Bounds (745.940, 797.020) (746.280, 797.300)
False : No      Layer : M3     Bounds (794.120, 817.180) (796.280, 817.460)
False : No      Layer : M3     Bounds (841.280, 831.180) (842.020, 831.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3062 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 698.460) (737.740, 698.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 705.740) (694.840, 706.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (694.460, 735.980) (694.840, 736.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3063 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 665.420) (688.240, 665.700)
False : No      Layer : M3     Bounds (687.860, 703.500) (688.240, 703.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 750.540) (843.340, 750.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 776.860) (737.740, 777.140)
False : No      Layer : M3     Bounds (735.280, 827.260) (737.740, 827.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3068 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 778.540) (739.720, 778.820)
False : No      Layer : M3     Bounds (738.020, 824.460) (739.720, 824.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3074 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.960, 720.300) (744.340, 720.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3083 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 641.900) (685.600, 642.180)
False : No      Layer : M3     Bounds (685.280, 658.140) (685.600, 658.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 668.780) (746.280, 669.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3085 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 671.020) (740.280, 671.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_3095 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.040, 670.460) (737.740, 670.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_861 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 701.820) (740.280, 702.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_862 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 725.340) (743.680, 725.620)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 30
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_862 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 726.460) (737.740, 726.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.780, 812.700) (796.280, 812.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_907 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 828.940) (836.080, 829.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_937 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (742.640, 771.820) (744.340, 772.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_937 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 751.660) (746.280, 751.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_937 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 748.860) (737.740, 749.140)
False : No      Layer : M3     Bounds (739.340, 752.220) (739.720, 752.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_940 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 720.860) (746.280, 721.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_940 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 724.780) (739.060, 725.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_940 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 720.860) (740.280, 721.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_942 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.980, 714.140) (743.680, 714.420)
False : No      Layer : M3     Bounds (743.300, 691.180) (743.680, 691.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_942 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 694.540) (737.740, 694.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_973 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 654.780) (738.400, 655.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_974 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 667.660) (740.280, 667.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_976 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 655.900) (743.020, 656.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_976 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (737.360, 656.460) (737.740, 656.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_978 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.940, 664.300) (746.280, 664.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_981 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 654.780) (742.360, 655.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_983 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 656.460) (746.280, 656.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ALU_32_INST/n_993 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 634.060) (694.840, 634.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[10] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.780, 772.940) (796.280, 773.220)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 31
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.540, 775.180) (786.580, 775.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 794.780) (787.240, 795.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 792.540) (790.280, 792.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[12] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 791.980) (795.820, 792.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.540, 803.180) (787.240, 803.460)
False : No      Layer : M3     Bounds (787.520, 803.740) (789.880, 804.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 795.900) (836.740, 796.180)
False : No      Layer : M3     Bounds (837.680, 803.180) (838.060, 803.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[16] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (839.000, 806.540) (840.040, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[18] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 817.180) (838.720, 817.460)
False : No      Layer : M3     Bounds (838.340, 809.340) (839.380, 809.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 655.340) (796.280, 655.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/acc[3] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 644.700) (746.280, 644.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[7] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.960, 683.900) (744.340, 684.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/acc[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 769.580) (785.920, 769.860)
False : No      Layer : M3     Bounds (785.540, 758.380) (787.240, 758.660)
False : No      Layer : M3     Bounds (787.520, 754.460) (789.880, 754.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 691.180) (746.280, 691.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 634.060) (736.420, 634.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.380, 640.780) (736.420, 641.060)
False : No      Layer : M3     Bounds (735.380, 644.700) (736.420, 644.980)
False : No      Layer : M3     Bounds (735.380, 812.140) (735.760, 812.420)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 32
False : No      Layer : M3     Bounds (738.020, 781.900) (739.720, 782.180)
False : No      Layer : M3     Bounds (839.660, 791.980) (840.040, 792.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.320, 611.660) (743.680, 611.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 665.420) (745.660, 665.700)
False : No      Layer : M3     Bounds (841.280, 773.500) (843.340, 773.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 664.300) (685.600, 664.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 627.340) (737.740, 627.620)
False : No      Layer : M3     Bounds (735.280, 744.940) (736.420, 745.220)
False : No      Layer : M3     Bounds (736.040, 811.020) (737.740, 811.300)
False : No      Layer : M3     Bounds (736.700, 644.140) (737.080, 644.420)
False : No      Layer : M3     Bounds (738.680, 831.740) (740.280, 832.020)
False : No      Layer : M3     Bounds (739.340, 605.500) (739.720, 605.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 607.180) (736.420, 607.460)
False : No      Layer : M3     Bounds (737.360, 642.460) (739.720, 642.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_cmd[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 636.300) (739.720, 636.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[13] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 810.460) (796.280, 810.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[13] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.840, 806.540) (790.280, 806.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[17] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 830.620) (838.060, 830.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[19] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 824.460) (846.280, 824.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[19] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.020, 816.620) (840.040, 816.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[3] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 638.540) (746.280, 638.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[3] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (739.340, 620.060) (740.280, 620.340)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 33
Regular Via of Net DTMF_INST/TDSP_CORE_INST/alu_result[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (743.300, 659.260) (743.680, 659.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/alu_result[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 645.260) (746.280, 645.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/dmov_inc & Special Wire of Net VSS
False : No      Layer : M3     Bounds (836.360, 550.060) (836.740, 550.340)
False : No      Layer : M3     Bounds (836.360, 654.220) (836.740, 654.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/enc_go_port & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 639.660) (841.360, 639.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/gz & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 650.300) (846.280, 650.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[10] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 629.580) (842.020, 629.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 621.180) (835.420, 621.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[11] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 584.780) (842.680, 585.060)
False : No      Layer : M3     Bounds (841.280, 604.380) (842.020, 604.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[11] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 667.100) (844.000, 667.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 589.820) (788.560, 590.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.840, 705.180) (790.280, 705.460)
False : No      Layer : M3     Bounds (835.280, 579.740) (836.740, 580.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[12] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 664.860) (845.270, 665.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.840, 667.660) (789.220, 667.940)
False : No      Layer : M3     Bounds (835.280, 545.020) (835.420, 545.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[14] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[15]
False : No      Layer : M3     Bounds (767.060, 560.140) (767.440, 560.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[14] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 612.780) (795.820, 613.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 618.380) (787.900, 618.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 645.260) (796.280, 645.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 614.460) (846.280, 614.740)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 34
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 573.580) (846.280, 573.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[8] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 674.940) (842.680, 675.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 620.060) (835.420, 620.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 660.940) (841.360, 661.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/ir[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.640, 604.940) (842.680, 605.220)
False : No      Layer : M3     Bounds (843.620, 585.340) (844.000, 585.620)
False : No      Layer : M3     Bounds (843.620, 640.220) (845.930, 640.500)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/ir[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.680, 578.620) (838.720, 578.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/lez & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 634.060) (841.360, 634.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/lez & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 632.940) (836.740, 633.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/lz & Special Wire of Net VDD
False : No      Layer : M3     Bounds (842.960, 635.180) (843.340, 635.460)
False : No      Layer : M3     Bounds (843.620, 650.860) (846.280, 651.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 669.340) (796.280, 669.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 622.300) (796.280, 622.580)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[10] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.780, 716.380) (796.280, 716.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 781.900) (787.240, 782.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 716.380) (836.080, 716.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[11] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 761.180) (845.270, 761.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 723.660) (788.560, 723.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 725.340) (836.740, 725.620)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 778.540) (790.280, 778.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 776.300) (836.740, 776.580)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 35
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[13] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 711.340) (846.280, 711.620)
False : No      Layer : M3     Bounds (844.280, 730.940) (846.280, 731.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[13] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 733.180) (835.420, 733.460)
False : No      Layer : M3     Bounds (835.280, 780.780) (835.420, 781.060)
False : No      Layer : M3     Bounds (837.020, 708.540) (840.040, 708.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[14] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.780, 761.180) (795.820, 761.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[14] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (838.340, 728.700) (839.380, 728.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[15] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 761.740) (796.280, 762.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 732.620) (790.280, 732.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 695.100) (836.080, 695.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 677.740) (836.740, 678.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 654.780) (796.280, 655.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 685.580) (836.740, 685.860)
False : No      Layer : M3     Bounds (837.020, 680.540) (837.400, 680.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[3] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 670.460) (836.080, 670.740)
False : No      Layer : M3     Bounds (835.700, 683.340) (836.080, 683.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 746.060) (796.280, 746.340)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[4] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 671.020) (835.420, 671.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[5] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (844.280, 688.940) (845.270, 689.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[5] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 690.620) (835.420, 690.900)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[6] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 692.860) (836.080, 693.140)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mdr[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.700, 765.100) (836.080, 765.380)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 36
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mdr[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 720.860) (845.930, 721.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[10] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 706.300) (646.280, 706.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[12] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (591.280, 713.020) (592.540, 713.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (589.520, 713.020) (590.280, 713.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (639.020, 710.220) (639.400, 710.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.720, 730.380) (637.420, 730.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[16] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 725.900) (646.280, 726.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[17] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 721.420) (646.280, 721.700)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 670.460) (646.280, 670.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[21] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.660, 742.140) (642.040, 742.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[21] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 741.020) (646.280, 741.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[28] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (688.520, 771.260) (690.220, 771.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[29] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (642.980, 769.580) (645.340, 769.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[30] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (688.520, 760.060) (690.280, 760.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[3] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 680.540) (646.280, 680.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 685.020) (646.280, 685.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[5] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.720, 691.180) (637.420, 691.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[6] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 701.260) (646.280, 701.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/mpy_result[7] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.720, 695.660) (637.420, 695.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (586.220, 704.620) (589.240, 704.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/mpy_result[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 699.580) (635.440, 699.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.040, 655.900) (737.740, 656.180)
*********** SOC ENCOUNTER Violation Browser Report **********
Report File Name :  DTMF_CHIP.viols.rpt        Page : 37
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 831.180) (737.740, 831.460)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 815.500) (737.740, 815.780)
False : No      Layer : M3     Bounds (738.680, 822.220) (739.060, 822.500)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[12] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 797.580) (788.560, 797.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 670.460) (693.520, 670.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.880, 655.900) (687.580, 656.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[27] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 800.380) (843.340, 800.660)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 663.180) (693.520, 663.460)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 659.260) (786.580, 659.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[31] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 751.100) (789.880, 751.380)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[3] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.880, 822.780) (687.580, 823.060)
False : No      Layer : M3     Bounds (785.280, 666.540) (786.580, 666.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.780, 704.620) (696.280, 704.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 695.660) (746.280, 695.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[4] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 710.780) (686.260, 711.060)
False : No      Layer : M3     Bounds (686.540, 821.660) (686.920, 821.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[6] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 746.060) (696.280, 746.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[6] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 761.180) (696.280, 761.460)
False : No      Layer : M3     Bounds (745.280, 731.500) (746.280, 731.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[7] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 755.580) (739.060, 755.860)
False : No      Layer : M3     Bounds (736.040, 741.580) (736.420, 741.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 771.260) (736.420, 771.540)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 38
False : No      Layer : M3     Bounds (735.280, 785.820) (736.420, 786.100)
False : No      Layer : M3     Bounds (738.020, 758.940) (738.400, 759.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 781.340) (739.060, 781.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (744.620, 789.740) (745.000, 790.020)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opa[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 811.580) (740.280, 811.860)
False : No      Layer : M3     Bounds (738.680, 791.980) (740.280, 792.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[0] & Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[1]
False : No      Layer : M3     Bounds (668.720, 781.900) (669.100, 782.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (543.320, 737.100) (545.020, 737.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (538.700, 751.660) (539.080, 751.940)
False : No      Layer : M3     Bounds (787.520, 678.300) (787.900, 678.580)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.040, 816.060) (736.420, 816.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 784.140) (789.220, 784.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[15] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.820, 793.660) (694.840, 793.940)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[15] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.280, 736.540) (792.520, 736.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 801.500) (687.580, 801.780)
False : No      Layer : M3     Bounds (687.200, 811.580) (687.580, 811.860)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 669.340) (694.840, 669.620)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (688.520, 658.140) (688.900, 658.420)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[24] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 782.460) (842.020, 782.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[27] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 799.820) (842.680, 800.100)
False : No      Layer : M3     Bounds (842.300, 793.100) (842.680, 793.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[28] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.020, 770.140) (840.040, 770.420)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 39
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.280, 676.620) (793.840, 676.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 785.820) (686.260, 786.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[30] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (789.500, 760.060) (790.280, 760.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[3] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.280, 686.700) (793.840, 686.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[3] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 691.180) (686.920, 691.460)
False : No      Layer : M3     Bounds (686.540, 795.900) (687.580, 796.180)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[4] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 705.180) (694.180, 705.460)
False : No      Layer : M3     Bounds (743.960, 695.660) (744.340, 695.940)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[4] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 711.340) (686.920, 711.620)
False : No      Layer : M3     Bounds (687.200, 796.460) (688.240, 796.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[5] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 799.260) (696.280, 799.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[5] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 786.380) (685.600, 786.660)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[6] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.140, 745.500) (694.840, 745.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[6] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.140, 785.820) (696.280, 786.100)
False : No      Layer : M3     Bounds (693.800, 737.100) (694.840, 737.380)
False : No      Layer : M3     Bounds (695.120, 762.860) (696.160, 763.140)
False : No      Layer : M3     Bounds (744.620, 730.940) (746.280, 731.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 816.620) (691.540, 816.900)
False : No      Layer : M3     Bounds (694.460, 805.980) (694.840, 806.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.780, 818.860) (696.280, 819.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (688.520, 816.620) (690.280, 816.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[7] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 743.260) (737.740, 743.540)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 40
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[8] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (693.800, 822.220) (694.840, 822.500)
False : No      Layer : M3     Bounds (695.120, 806.540) (696.280, 806.820)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[8] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 696.780) (795.820, 697.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (736.700, 781.900) (737.740, 782.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[8] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.680, 752.780) (740.280, 753.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (694.460, 826.140) (694.840, 826.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.280, 791.980) (746.280, 792.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (738.020, 811.020) (740.280, 811.300)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/opb[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (740.000, 802.060) (740.280, 802.340)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 671.020) (795.160, 671.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[10] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.280, 715.260) (793.180, 715.540)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[11] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 711.340) (642.040, 711.620)
False : No      Layer : M3     Bounds (646.280, 714.140) (646.280, 714.420)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 708.540) (786.580, 708.820)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[13] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 723.100) (641.380, 723.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[14] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 724.780) (641.380, 725.060)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[14] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.720, 730.940) (638.740, 731.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[14] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (639.680, 724.780) (640.280, 725.060)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[20] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 745.500) (796.280, 745.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[27] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 774.060) (691.540, 774.340)
False : No      Layer : M3     Bounds (691.820, 777.980) (692.860, 778.260)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[29] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 763.980) (694.840, 764.260)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 41
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 673.820) (642.040, 674.100)
False : No      Layer : M3     Bounds (646.280, 677.740) (646.280, 678.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[30] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 761.740) (787.900, 762.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[31] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (692.480, 753.900) (693.520, 754.180)
False : No      Layer : M3     Bounds (693.140, 658.700) (696.280, 658.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[31] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 658.700) (746.280, 658.980)
False : No      Layer : M3     Bounds (791.280, 658.700) (796.280, 658.980)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/p[31] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 658.700) (740.280, 658.980)
False : No      Layer : M3     Bounds (785.280, 658.700) (790.280, 658.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[4] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 688.380) (635.440, 688.660)
False : No      Layer : M3     Bounds (635.720, 690.620) (638.740, 690.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/p[6] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 702.380) (635.440, 702.660)
False : No      Layer : M3     Bounds (635.720, 698.460) (636.100, 698.740)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/phi_3 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 548.940) (796.280, 549.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/phi_6 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (843.620, 499.100) (845.930, 499.380)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/phi_6 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (786.860, 519.260) (787.240, 519.540)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/phi_6 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.180, 521.500) (790.280, 521.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_addrs_in[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (841.280, 662.620) (842.680, 662.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/port_addrs_in[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (836.360, 660.940) (836.740, 661.220)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/port_addrs_in[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 714.700) (796.280, 714.980)
False : No      Layer : M3     Bounds (843.620, 656.460) (844.660, 656.740)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[0] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (541.280, 339.500) (546.280, 339.780)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 42
False : No      Layer : M3     Bounds (591.280, 339.500) (596.280, 339.780)
False : No      Layer : M3     Bounds (641.280, 339.500) (646.280, 339.780)
False : No      Layer : M3     Bounds (691.280, 339.500) (696.280, 339.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (585.280, 339.500) (590.280, 339.780)
False : No      Layer : M3     Bounds (635.280, 339.500) (640.280, 339.780)
False : No      Layer : M3     Bounds (685.280, 339.500) (690.280, 339.780)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 623.980) (746.280, 624.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 623.980) (740.280, 624.260)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[2] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 618.940) (746.280, 619.220)
False : No      Layer : M3     Bounds (791.280, 618.940) (796.280, 619.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[2] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 618.940) (740.280, 619.220)
False : No      Layer : M3     Bounds (785.280, 618.940) (790.280, 619.220)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/port_data_in[3] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.280, 410.620) (796.280, 410.900)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/sel_op_a[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.480, 633.500) (793.840, 633.780)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/sel_op_b[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (795.440, 664.860) (796.280, 665.140)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/sel_op_b[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (788.840, 627.900) (790.280, 628.180)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[0] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.020, 643.580) (838.060, 643.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[10] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 775.740) (785.920, 776.020)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[11] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 783.580) (787.900, 783.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[12] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (796.100, 783.580) (796.280, 783.860)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[15] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 785.820) (838.060, 786.100)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[1] & Special Wire of Net VDD
False : No      Layer : M3     Bounds (794.120, 644.700) (795.820, 644.980)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 43
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[1] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (786.860, 643.020) (787.240, 643.300)
Regular Wire of Net DTMF_INST/TDSP_CORE_INST/top[3] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (787.520, 630.700) (789.880, 630.980)
Regular Via of Net DTMF_INST/TDSP_CORE_INST/top[9] & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 766.220) (786.580, 766.500)
Regular Via of Net DTMF_INST/clk & Regular Wire of Net DTMF_INST/m_clk
False : No      Layer : M3     Bounds (668.720, 500.780) (669.760, 501.060)
Regular Wire of Net DTMF_INST/m_clk__L1_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 338.940) (646.280, 339.220)
Regular Wire of Net DTMF_INST/m_clk__L1_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 338.940) (640.280, 339.220)
Regular Wire of Net DTMF_INST/m_clk__L2_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 340.060) (646.280, 340.340)
Regular Wire of Net DTMF_INST/m_clk__L2_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 340.060) (640.280, 340.340)
Regular Wire of Net DTMF_INST/m_clk__L4_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 340.060) (696.280, 340.340)
False : No      Layer : M3     Bounds (741.280, 340.060) (746.280, 340.340)
Regular Via of Net DTMF_INST/m_clk__L4_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (745.940, 428.540) (746.280, 428.820)
Regular Wire of Net DTMF_INST/m_clk__L4_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 340.060) (690.280, 340.340)
False : No      Layer : M3     Bounds (735.280, 340.060) (740.280, 340.340)
Regular Wire of Net DTMF_INST/m_clk__L5_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 430.780) (696.280, 431.060)
False : No      Layer : M3     Bounds (741.280, 430.780) (746.280, 431.060)
Regular Via of Net DTMF_INST/m_clk__L5_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (686.540, 496.860) (688.240, 497.140)
False : No      Layer : M3     Bounds (687.860, 430.780) (690.280, 431.060)
Regular Wire of Net DTMF_INST/m_clk__L5_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 430.780) (740.280, 431.060)
Regular Via of Net DTMF_INST/m_clk__L6_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (687.860, 499.660) (689.560, 499.940)
Regular Wire of Net DTMF_INST/m_clk__L7_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (695.120, 497.980) (696.280, 498.260)
False : No      Layer : M3     Bounds (741.280, 478.940) (746.280, 479.220)
False : No      Layer : M3     Bounds (791.280, 478.940) (796.280, 479.220)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 44
False : No      Layer : M3     Bounds (841.280, 478.940) (846.280, 479.220)
Regular Wire of Net DTMF_INST/m_clk__L7_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 478.940) (740.280, 479.220)
False : No      Layer : M3     Bounds (785.280, 478.940) (790.280, 479.220)
False : No      Layer : M3     Bounds (835.280, 478.940) (840.280, 479.220)
Regular Wire of Net DTMF_INST/m_clk__L8_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 783.020) (696.280, 783.300)
False : No      Layer : M3     Bounds (741.280, 783.020) (746.280, 783.300)
False : No      Layer : M3     Bounds (791.280, 795.900) (791.860, 796.180)
Regular Via of Net DTMF_INST/m_clk__L8_N0 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (791.480, 802.060) (791.860, 802.340)
False : No      Layer : M3     Bounds (791.480, 804.860) (796.280, 805.140)
False : No      Layer : M3     Bounds (841.280, 804.860) (846.280, 805.140)
Regular Wire of Net DTMF_INST/m_clk__L8_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 783.020) (690.280, 783.300)
False : No      Layer : M3     Bounds (735.280, 783.020) (740.280, 783.300)
Regular Via of Net DTMF_INST/m_clk__L8_N0 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (785.280, 771.820) (789.220, 772.100)
False : No      Layer : M3     Bounds (785.280, 795.900) (790.280, 796.180)
False : No      Layer : M3     Bounds (835.280, 804.860) (840.280, 805.140)
Regular Wire of Net DTMF_INST/m_clk__L8_N1 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 684.460) (646.280, 684.740)
Regular Via of Net DTMF_INST/m_clk__L8_N1 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.280, 699.020) (642.040, 699.300)
False : No      Layer : M3     Bounds (641.280, 731.500) (646.280, 731.780)
False : No      Layer : M3     Bounds (641.660, 695.100) (646.280, 695.380)
False : No      Layer : M3     Bounds (642.320, 691.180) (642.700, 691.460)
False : No      Layer : M3     Bounds (691.280, 754.460) (696.280, 754.740)
False : No      Layer : M3     Bounds (741.280, 754.460) (746.280, 754.740)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 45
False : No      Layer : M3     Bounds (791.280, 634.060) (796.280, 634.340)
False : No      Layer : M3     Bounds (792.800, 640.780) (793.180, 641.060)
False : No      Layer : M3     Bounds (841.280, 649.740) (846.280, 650.020)
Regular Via of Net DTMF_INST/m_clk__L8_N1 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 677.740) (635.440, 678.020)
Regular Wire of Net DTMF_INST/m_clk__L8_N1 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 684.460) (640.280, 684.740)
False : No      Layer : M3     Bounds (635.280, 711.900) (635.440, 712.180)
False : No      Layer : M3     Bounds (635.280, 721.420) (635.440, 721.700)
False : No      Layer : M3     Bounds (635.280, 725.340) (635.440, 725.620)
False : No      Layer : M3     Bounds (635.280, 731.500) (640.280, 731.780)
False : No      Layer : M3     Bounds (685.280, 754.460) (690.280, 754.740)
False : No      Layer : M3     Bounds (685.280, 761.740) (687.580, 762.020)
False : No      Layer : M3     Bounds (686.540, 763.980) (687.580, 764.260)
False : No      Layer : M3     Bounds (735.280, 754.460) (740.280, 754.740)
False : No      Layer : M3     Bounds (785.280, 634.060) (790.280, 634.340)
False : No      Layer : M3     Bounds (835.280, 649.740) (840.280, 650.020)
Regular Wire of Net DTMF_INST/m_clk__L8_N2 & Special Wire of Net VDD
False : No      Layer : M3     Bounds (741.280, 610.540) (746.280, 610.820)
False : No      Layer : M3     Bounds (791.280, 622.860) (796.280, 623.140)
False : No      Layer : M3     Bounds (841.280, 493.500) (846.280, 493.780)
False : No      Layer : M3     Bounds (841.280, 622.860) (846.280, 623.140)
Regular Wire of Net DTMF_INST/m_clk__L8_N2 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (735.280, 610.540) (740.280, 610.820)
False : No      Layer : M3     Bounds (785.280, 622.860) (790.280, 623.140)
Regular Via of Net DTMF_INST/m_clk__L8_N2 & Special Wire of Net VSS
False : No      Layer : M3     Bounds (835.280, 490.140) (840.040, 490.420)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 46
False : No      Layer : M3     Bounds (835.280, 622.860) (840.280, 623.140)
False : No      Layer : M3     Bounds (837.680, 484.540) (840.040, 484.820)
False : No      Layer : M3     Bounds (839.000, 493.500) (840.280, 493.780)
Regular Wire of Net DTMF_INST/spi_clk & Special Wire of Net VDD
False : No      Layer : M3     Bounds (691.280, 541.100) (696.280, 541.380)
False : No      Layer : M3     Bounds (741.280, 541.100) (746.280, 541.380)
Regular Wire of Net DTMF_INST/spi_clk & Special Wire of Net VSS
False : No      Layer : M3     Bounds (685.280, 541.100) (690.280, 541.380)
False : No      Layer : M3     Bounds (735.280, 541.100) (740.280, 541.380)
Regular Via of Net ibiasI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M3     Bounds (355.580, 540.540) (355.600, 540.820)
Regular Via of Net pllrstI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M3     Bounds (355.580, 380.940) (355.600, 381.220)
Regular Via of Net refclkI & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M3     Bounds (355.580, 500.780) (355.600, 501.060)
Regular Via of Net scan_enI & Special Wire of Net VDD
False : No      Layer : M3     Bounds (641.660, 710.780) (642.040, 711.060)
Regular Wire of Net scan_enI & Special Wire of Net VDD
False : No      Layer : M3     Bounds (645.620, 708.540) (646.280, 708.820)
False : No      Layer : M3     Bounds (645.620, 729.260) (646.280, 729.540)
Regular Via of Net scan_enI & Special Wire of Net VSS
False : No      Layer : M3     Bounds (635.280, 678.860) (635.440, 679.140)
Regular Wire of Net scan_enI & Special Wire of Net VSS
False : No      Layer : M3     Bounds (837.680, 490.700) (838.720, 490.980)
Regular Via of Net vcomO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M3     Bounds (355.580, 420.700) (355.600, 420.980)
Regular Via of Net vcopO & Blockage of Cell DTMF_INST/PLLCLK_INST
False : No      Layer : M3     Bounds (355.580, 461.020) (355.600, 461.300)
Regular Via of Net ibiasI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.900, 540.540) (354.280, 540.820)
False : No      Layer : M4     Bounds (353.900, 541.660) (354.280, 541.940)
Regular Wire of Net ibiasI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.950, 540.540) (354.230, 541.940)
Regular Via of Net pllrstI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (354.560, 380.940) (354.940, 381.220)
False : No      Layer : M4     Bounds (354.560, 385.420) (354.940, 385.700)
Report File Name :  DTMF_CHIP.viols.rpt        Page : 47
Regular Wire of Net pllrstI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (354.610, 380.940) (354.890, 385.700)
Regular Via of Net refclkI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.900, 500.780) (354.280, 501.060)
False : No      Layer : M4     Bounds (353.900, 501.340) (354.280, 501.620)
Regular Wire of Net refclkI & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.950, 500.780) (354.230, 501.620)
Regular Via of Net vcomO & Special Wire of Net VDD
False : No      Layer : M4     Bounds (352.580, 420.700) (352.960, 420.980)
Regular Via of Net vcopO & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.240, 458.220) (353.620, 458.500)
False : No      Layer : M4     Bounds (353.240, 461.020) (353.620, 461.300)
Regular Wire of Net vcopO & Special Wire of Net VDD
False : No      Layer : M4     Bounds (353.290, 458.220) (353.570, 461.300)
Regular Via of Net scan_enI & Blockage of Cell IOPADS_INST/Pscanenip
False : No      Layer : M5     Bounds (234.390, 340.150) (234.870, 340.390)
Regular Wire of Net scan_enI & Blockage of Cell IOPADS_INST/Pscanenip
False : No      Layer : M5     Bounds (234.490, 340.150) (235.000, 340.340)
False : No      Layer : M6     Bounds (234.360, 340.330) (234.900, 340.470)
False : No      Layer : Via23     Bounds (767.120, 560.150) (767.380, 560.410)
Regular Via of Net ibiasI & Blockage of Cell IOPADS_INST/Pibiasip
False : No      Layer : Via56     Bounds (234.520, 612.740) (234.810, 613.100)
Regular Via of Net refclkI & Blockage of Cell IOPADS_INST/Prefclkip
False : No      Layer : Via56     Bounds (234.520, 818.260) (234.810, 818.620)
Regular Via of Net scan_clkI & Blockage of Cell IOPADS_INST/Pscanckip
False : No      Layer : Via56     Bounds (234.520, 271.140) (234.810, 271.150)
Regular Via of Net test_modeI & Blockage of Cell IOPADS_INST/Ptestmdip
False : No      Layer : Via56     Bounds (234.520, 407.220) (234.810, 407.580)
Regular Via of Net vcomO & Blockage of Cell IOPADS_INST/Pvcomop
False : No      Layer : Via56     Bounds (234.520, 680.660) (234.810, 680.860)
Regular Via of Net vcopO & Blockage of Cell IOPADS_INST/Pvcopop
False : No      Layer : Via56     Bounds (234.520, 749.940) (234.810, 750.300)
[/CODE]
  • Kari
    Kari over 15 years ago
     Don't run verifyConnectivity or verifyGeometry if you still have trialRoutes in your design. These are not completely legal routes. Run the verify steps after the design has been through NanoRoute.
