  3. issue with adding Mfill
  • Subscribers 93
  • Views 15539
KVBABU
KVBABU over 15 years ago
Hi
Iam  working on design with TSMC 28nm technology, in which i tried to add Metal fill . Even with default settings in encounter GUI , i could not able to add Mfill, diplaying below error and warning  messages:
addMetalFill -layer { M1 M2 M3 M4 M5 M6 } -nets { vss vdd } -timingAware off
**ERROR: (ENCMF-192):   Spacing table is too big (width:440 length:440)
End metal filling: cpu:  0:00:00.0,  real:  0:00:00.0,  peak mem:  651.17  megs.
**WARN: (ENCMF-9):      5 memory pool(s) not released!
*** 5 memory pool(s) in use ***
 I could not able guess , from where the tool is picking up the spacing table  (width:440 length:440).
Kindly help me to resolve this issue.
Thanks & Regards,
K.VISWANADH BABU
  • Kari
    Kari over 15 years ago
     Before doing addMetalFill, you have to use setMetalFill to set up all of your widths, spacings, etc. Check the docs for setMetalFill and give that a try.
  • KVBABU
    Hi Kari,
    Thanks for your immediate reply. As per documents, i have enough info. conatined in my tech lef. The only parameter missing which i was observed is LEF58_FILLTOFILLSPACING. As an experiment , i defined this value w.r.t. values in verication rule files.But, i could not able to suceessed.
    K.VISWANADH BABU
  • Kari
     I have never seen the tech LEF contain enough info. I strongly recommend you use setMetalFill for everything. Make sure you get the data from your design rule manual - the numbers in the tech lef may not be right.
