  3. Cadence ELC not recognising SPECTRE format
  • Subscribers 96
  • Views 16169
eklikeroomys
eklikeroomys over 15 years ago
Halo,
I am using ELC to characterise a new standard cell library. I am using a SPECTRE .scs model file, but it seems that ELC is not recognising this file format correctly, as it complains about library and section declarations which are present in the model file. I assume that my command and/or elccfg file is not set up correctly for using spectre.
This is the contents of my command file:
db_open cell_digital
db_prepare -f
db_spice -s spectre -keep_log -keep_wave
db_output -lib cell_digital.lib -process typical -state
db_close
exit
And this is the contents of my elccfg file:
# Specify the environment variable settings.
EC_SIM_USE_LSF=1;
EC_SIM_LSF_CMD=" ";
EC_SIM_LSF_PARALLEL=10;
EC_SIM_TYPE="spectre";
EC_SIM_NAME="spectre";
EC_SPICE_SIMPLIFY=1;
EC_CHAR="ECSM-TIMING ECSM-POWER";
SUBCKT="cell_digital_SPICE_netlist.scs";
MODEL="model_file.scs";
SETUP="setup.ss";
PROCESS="typical";
Can somebody guide me into the right direction?
Thank you,
  • GreenGraphene
    GreenGraphene over 13 years ago
     eklikeroomys
    Well, surprised, am now at the same point and every kind of situation I am facing now is what you had posted on. Did u find an answer and can you pl share it with us ?
  • Hatkar
    Hatkar over 13 years ago
     write your problem in detail, not getting what problem you are facing
  • Willvlsi
    Willvlsi over 12 years ago
    I have the same problem with eklikeroomys.
    I use a model file from TSMC, it defines multiple sections for different processes and corner. At each section, it defines many parameters which has unique values to that process and/or corner, then it include the mos model which uses these parameter to describe its characters.
    The ELC could direct into the right section and include the mos model well, but it seems it does not recognize the parameter definition. It reports errors when I do "db_spice". Reported errors like:
    Error found by spectre during hierarchy flattening.
        ERROR (SFE-1999):
            "/home/abc/works/elc/foo.ipdb/NCH.device/simulate/model" 4: Model
            `nch.1': parameter `wmin': Unknown parameter name `dxw' found in
            expression.
    Can you help with this? Thanks in advance!
  • maple
    maple over 12 years ago
    Which version of spectre are you using? Please use a newer version spectre.
