  3. NanoRoute CRASH, need help.....VERSION SOC-E 52 Update ...
  • Subscribers 93
  • Views 14927
NanoRoute CRASH, need help.....VERSION SOC-E 52 Update 5
archive over 18 years ago
hi, all
Following is an excerpt from the encounter log file, the nanoroute just made a STACK TRACE....
#Total number of violations on LAYER M6 = 0
#Total number of violations on LAYER M7 = 0
#Total number of violations on LAYER M8 = 0
#Cpu time = 00:20:16
#Elapsed time = 00:05:45
#Increased memory = -34.00 (Mb)
#Total memory = 3671.00 (Mb)
#Peak memory = 4184.00 (Mb)
**DIAG[dbRipin.c:1254:dbiInitRipinJncList]: Assert "dbmRipinFirstChild(ppp) == p"
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(syStackTrace+0x127)[0x3c3f102]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter[0xc1a3db]
/lib64/libpthread.so.0[0x2a955963f8]
/lib64/libc.so.6[0x2a95df9150]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_Z26dbNetCleanupDuplicateRipinP6dbsNetc+0x10ea)[0x325be8e]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_Z16dbNetRipinToWireP6dbsNet+0xa60)[0x325e578]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN11PDZT_Export12export_ripinEP14PDBT_Cell_ViewP8PDBT_Netb+0x1cd)[0xdf16bd]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN11PDZT_Export12export_ripinEv+0x8e)[0xdf149e]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN11PDZT_Export10export_netEv+0xd4)[0xdf0994]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN11PDZT_Export13export_designEv+0x21b)[0xdef64b]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN11PDZT_Export11auto_exportEv+0x7b)[0xdef27b]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(_ZN9PDIT_Main8call_cmdEiPPcb+0x331)[0xdf8861]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(TclInvokeStringCommand+0x7d)[0x44dd3a7]
/data/XXXXXXX/tools/cadence/SOC52/tools/fe/bin/64bit/encounter(TclExecuteByteCode+0x89f)[0x44f7a04]
As we know, encounter just calls nanoroute to route the design, and then ripin the routed database, I think the RED line is where the problems come from, need expert to give me a answer, I dont have access to sourcelink........
BRs
Originally posted in cdnusers.org by eminemshow
    Would it be possible for you to work this issue through your local support contacts?
    Bob
    Originally posted in cdnusers.org by BobD
