  3. Encounter Library Characterizer alf2vhdl problem
  • Subscribers 95
  • Views 14757
eklikeroomys
eklikeroomys over 15 years ago
I used ELC to characterize a standard cell library, and used the alf2vhdl tool to generate the vhdl VITAL timing file for the library.
For some reason, the VHDL format written out by alf2vhdl is not compatible with Ambit, which I need to use to synthesize a design.
There doesnt seem to be an option for making the format compatible, am I missing something or is there another tool that I can use to generate the VITAL file?
  • J2mh
    J2mh over 15 years ago
     Have you thought to prove the alf2lib command? For example
     alf2lib -alf *.alf -cap typ -check typ -delay typ -lib *.typ.lib -max_load -typ -power typ -supply "VDD VSS"
     Regards.
