  3. *Fence* *SRC* *MME* Buffers in Clock Tree
  • Subscribers 94
  • Views 15286
Nataraja G
Nataraja G over 15 years ago
With 10.11USR1 enconter  we are seeing new type of buffers being added at CTS
*MMExc__L1_I0 these kind of naming convention was given if a pin was declared excludedPin in clock spec file
but in 10.1 *MMExc*  buffers are being added without specfying excludedPin and this is not because of  loops in clock path ( obviosuly with ckSynthesis -breakloop we are expected to see excluded buffer at loop backs )
I have never seen Insance names with *Fence* and *SRC*   in clock path
 What do they signify ? i have searched fetxtref and socUG for these things but havn't found anything
hope i am clear ,
 Nataraja
its good to be back :)
  • Kari
    Kari over 15 years ago
     Welcome back!
    I think SRC has to do with balancing to an output port, and Fence could be due to power domains or setCTSMode -honorFence, or maybe some other things. Do any of these make sense for your design?
  • Nataraja G
     we have set this,
     setCTSMode -honorFence false
     still fence buffer's are added and we dont have power domains in the design
    Fence buffers are being added to preserve a module port , in SDC file we have generated clock definitions at these ports
    So ckSynthesis is automatically preserving them ( though i havn't specified them in clock spec file ) ,
    while i was browing in schematic viewer i found this  common to all generated clock's
    i dont think SRC is for balancing Output ports , tool uses CASACDE buffer's if that is the case
    Regards
    Nataraja
