  3. Proving that a given netlist A results in better layout...
  • Subscribers 94
  • Views 14832
Proving that a given netlist A results in better layout than netlist B
asinghct
asinghct over 15 years ago
Hi, I have a very general question, I have two netlists A & B, basically same functionality but somewhat different synthesis( though mapping to same library) in front end. I need to see which one of them is doing better in terms of layout. What parameters can I use to compare two layouts from soc encounter. Thanks Amit
  • Kari
    Kari over 15 years ago
     It may depend what your goals are. You can compare things like area, timing closure, power, std cell utilization, routing congestion, etc. If your goal is the lowest power, you may not care if it's harder to close timing. If quick timing closure is the goal, you may not care if you use a lot of area or power.
