  3. How can I specify the number of cores RTL compiler uses...
  • Subscribers 94
  • Views 16364
How can I specify the number of cores RTL compiler uses for processing?
mamsadegh
mamsadegh over 15 years ago
 Hi
 In soc encouter , we can simply use
setMultiCpuUsage
command to specify the number of cpu cores we want to be used by encouter.
for example on a system with a CPU of 4 cores you can enable all of them.
(I am talking about local cpu cores, i'm not interested in network ones)
 how can i do the same in rc?
does rc automatically uses all of the available cpu cores in the local system?
thanks.
  • grasshopper
    grasshopper over 15 years ago
     By default, license feature RTL_Compiler_Ultra can do 2 threads and are enabled by default. Beyond that you have to enable manually using super_thread_servers attribute
     For example
    set_attr super_thread_servers {my_host my_host my_host}  /
     will spawn 3 threads on server my_host. Note that threads are lighter processe
     alternatively you can use something like
      set_attr super_thread_servers [string repeat "localhost " $number_cpus] /
    with similar results. As you can imagine there a number of other options to support network resources, load balancing applications, or simply customize to your needs.
    hope this helps,
    gh-
