  3. Running time with VCD annotation
  • Subscribers 94
  • Views 15090
vaswan
vaswan over 15 years ago
Hi all,
   'm running  a design (size of 250 K) for dynamic  low power analysis with VCD annotation
and took huge amount of running time.
Running with Saif annotation went fine with lesser running time.
But when VCD file annotated with design(RTL) it took nearly two days and still it was not completed.
Can anybody give  the reason why it takes quite lot of time ?
  • Scrivner
    Scrivner over 15 years ago
    I sometimes have had trouble with this using the VCD also. Make sure you use a small window of time for analysis. Try using a Start and Stop time that contains only a few clock cycles. I sometimes still have trouble where the tool hangs. If this happens, try shutting down the tool and restarting. If you still have trouble, try using a different version of the tool.
