  3. DEF import to Virtuoso
  • Subscribers 93
  • Views 15767
superman321
superman321 over 14 years ago
Im trying to import my DEF file from Encounter (Version 9.1) into Cadence Virtuoso (Version 5.1) to do my post P&R analysis, instead of using the GDS2 import from Encounter. I have successful in importing the design without errors EXCEPT for one, the layout is missing the metal LAYERS beneath the area marked PINS of same area. That is the only DRC error that I have. Any suggesting on why is acting up? thank in advance!
  • scudex
    scudex over 14 years ago
     just execute "Create Layer Generation"as follows and select your corrsponding layers.
    i.e.:
    <MetalX drw> AND <MetalX drw> = <MetalX pin>
     That's how it worked in ic5, as far as I remember.
    scudex
  • Scrivner
    Scrivner over 14 years ago
    What does this refer to? Where/How is this executed?
    Thanks!
  • superman321
    Virtuoso Menu, Create --> layer Generation Scudex, Many thanks for your reply, Sorry it didn't help me with my issue!...or I haven't executed it 'right'!?..I still dont have the Metal layer beneath the corresponding metal 'pin'. At present, im doing it manually!
  • scudex
     unfortunately I have to correct myself.
    If you have pin without drawing areas and get the message that pin is not covered by drawing, then
    - select the pins
    - create layer genereation with MetalX.pin AND MetalX.pin = MetalX.dwr
     This should work.
     >Hello,
     >check out whether your pin areas are selected. I guess they have to ... . And if selected try again layer generation.
     >Cheers
