  3. How to calculate the channel spacing between macros?
  • Subscribers 94
  • Views 20456
Ashok Nellore
Ashok Nellore over 15 years ago
Is this answer correct
channel spacing : width+spacing  x number of pins /vertical routing layers
  • J2mh
    J2mh over 15 years ago
    Yes it is.
    I think that it is better adding an aditional spacing because you can avoid violation with the side of one macros. The formula would be (width+spacing  x number of pins /vertical routing layers) + spacing
    Regards.
