  3. How to calculate Die size for core limited and Pad limited...
  • Subscribers 95
  • Views 19474
How to calculate Die size for core limited and Pad limited design?
Ashok Nellore
Ashok Nellore over 15 years ago
i Know that If the size of the core is a factor responsible for determining the size of the whole chip, then we say that our design is core limited.
But if the core is too small, and the number of pads are too much to the extent that the size of the chip is determined by the space required to place all the pads, then it is called pad limited.
Ideally speaking, a design should be core limited.
Then How we calculate  the Die size???
  • J2mh
    J2mh over 15 years ago
     The die size is determined by die corner rule, seal ring width and scribe line.
     Regards.
  • Kari
    Kari over 14 years ago
     You'll have to do some prototyping runs. You can pick a size that gives you a starting core utilization of, say, 55%, then take the design through place and route and see how things look. Is there placement congestion? Routing congestion? Do you have enough room for any special requirements, like space around analog macros, room for shielded analog routes, etc? The more designs you do, the more of a feel you'll get for sizing the core. It's very design/technology dependent, and there's no simple formula.
