  3. State Dependent Problem in db_output and alf2lib
  • Subscribers 94
  • Views 14192
Chiahsiang
Chiahsiang over 15 years ago
I'm currently using ETS 10.1  for library characterization. Here is a weried problem I got from 10.1 but it was not observed in previous version (ELC 8.1). It seems that the option -state is missing in both db_output and alf2lib?
 In elc.command, I have the following environmental variables:
set_var EC_POWER_OUTPUT_DEPENDENT 1
set_var EC_LEAKAGE_OUTPUT_DEPENDENT 1
 After I ran elc, I got the error as attached below:
elc>  db_state -p tt_1p0v_25c
State Generation by "tt_1p0v_25c" Process -pin_power -spnum 4
CELL : DFF1
elc>  db_output -report lib/hff_tt_1p0v_25c.alf.report -alf lib/hff_tt_1p0v_25c.alf -p tt_1p0v_25c -state
[WARNING(db_output)]Incorrect option specified as -state
DFF1           tt_1p0v_25c2011-08-23 22:35:52 (2011-08-24 02:35:52 GMT) 22 (100%)
elc>  alf2lib -state -alf lib/hff_tt_1p0v_25c.alf -lib lib/hff_tt_1p0v_25c.lib -def input/hff.def -leak_unit 1pW -max -supply {D CK Q} -power max -power_avg_all -slew_derate 0.5 -p 8 -state
Encounter - Library Characterizer - Version v10.10-p001_1 32-bit (12/01/2010 02:43:59)
[2000-2010]Cadence Design Systems, Inc. All rights reserved.
This work may not be copied, modified, re-published, uploaded, executed, or
distributed in any way, in any medium, whether in whole or in part, without
prior written permission from Cadence Design Systems, Inc.
UNKNOWN OPTION :-state
 In both commands, "-state" is treated an unknow option. But It's supposed to be there, and will generate the state dependent internal/leakage power for me, right?
Chia-Hsiang
