  3. Foreach_in_collection command
  • Subscribers 95
  • Views 21214
Socencounter
Socencounter over 15 years ago
Hi, Can any one please help me with the foreach_in_collection command? for each and every clocks in sdc file I need to add 10% clock period to the uncertainty values? Thanks
  • kazad
    kazad over 15 years ago
    You can try the following:
    foreach_in_collection clk [get_clocks *] {
       set period [get_attribute -quiet $clk period]
       set_clock_uncertainty -setup [expr $period * 0.1] [get_object_name $clk]
  • Socencounter
    Hi kazad, Thank you so much for the reply... Thanks
  • Socencounter
    Hi Kazad, As I want to add 10% clock of period to the original uncertainity value. Can you please tell me how to add to the original uncertainity value? Thanks
  • kazad
    I guess you wanted this:
        set current_setup_unc [get_attribute -quiet $clk setup_uncertainty]
        set current_hold_unc [get_attribute -quiet $clk hold_uncertainty]
        set_clock_uncertainty -setup [expr $period * 0.1 + $current_setup_unc] [get_object_name $clk]
        set_clock_uncertainty -hold [expr $period * 0.1 + $current_hold_unc] [get_object_name $clk]
  • Socencounter
    Hi kazad, Period of the master_clocks we can read from database...For generated clocks also we can read from dbs? Thanks for the help.. Thanks, Nirosha
