  3. Signal Integrity analysis in SOC Encounter
  • Subscribers 93
  • Views 14623
trav1s
trav1s over 14 years ago
Hello Cadence community.
Our foundry provides a 150nm process, and our designs are not high-speed by any means. They have not provided a noise library for use with SOC Encounter v9.12 (.cdb or .udn). I have tried to create a cdb file using the make_cdb utility, but there seems to be a major version problem with our spice model file, so I have not had any success with that.
I would like some advice as to what I should do. I know noise analysis plays a bigger role the smaller the process geometry is, but should noise be a concern in 150nm? Our foundry has provided other data files for the Cadence flow, so is the fact that they omitted a noise library a sign that it is not necessary? Is the Liberty timing library (.lib) enough?
  • Kari
    Kari over 13 years ago
     We never worried about SI at 130nm and above, but it did come back to haunt us in one 130nm project. I would say at 150nm you don't need to worry about it too much. Set the nanoroute variables for avoiding SI just to be safe; it will make sure you don't have too many long parallel routes.
  • Arslan
    Arslan over 12 years ago
     Hi, what about designing in 28nm process. what is the format or extention of SI libs. or how to generate them?
  • Kari
    Kari over 12 years ago
    the library vendor should deliver .cdb files for the std cells.
