  3. Problems connecting a padpin to a ring
  • Subscribers 95
  • Views 14976
timoue
timoue over 15 years ago
I am using sroute to connect my pad pins to the ring.  It works fine for ports that are defined with USE POWER and USE GROUND.  Unfortunately I have another pin that is optionally configured to connect to VSS or VDD.  This port is a wide port and is like a power/ground port but defined as such.  Is sroute the right command here?
  • J2mh
    J2mh over 15 years ago
    You can edit the lef file and add :
    - "USE POWER ;" below definition of pin.
    - "USE GROUND ;"  below definition of pin.
    For example :
    PIN PSEUDO_POWER
       DIRECTION INOUT ;
       USE POWER ;
    PIN PSEUDO_GROUND
       DIRECTION INOUT ;
       USE GROUND ;
    On the other hand you can do a connection by hand.
    Regards.
  • timoue
    changing the lef file is not an option.  The same port is configurable to attach to VDD or VSS.  If it is defined with USE POWER than I get an error when I try and attach it to VSS.  If it is USE GROUND, a VDD connection yields an error.  I can the logical connection to happen with a simple attachTerm.  The problem is that I cannot get sroute to route up the port to the core ring.
    Tim
