  3. IRdrop Analysis
  • Subscribers 94
  • Views 15520
IRdrop Analysis
yazdan
yazdan over 15 years ago
 I am going to do both static and dynamic IRdrop analysis. During static analysis I encountered a problem. I need LEF-Tech Map file. Would you please describe me how I can get this file.
By the way, If you have any tutorial on IRdrop analysis and the flow of this process, I'd appreciate if you would send me.
  • Scrivner
    Scrivner over 15 years ago
    Here is an example LEF layer map:
      # LEF layer map: tech lefdef lef
    metal METAL_1 lefdef METAL1
    metal METAL_2 lefdef METAL2
    metal METAL_3 lefdef METAL3
    metal METAL_4 lefdef METAL4
    metal METAL_5 lefdef METAL5
    metal METAL_6 lefdef METAL6
    via CONT lefdef CONT
    via VIA_1 lefdef VIA12
    via VIA_2 lefdef VIA23
    via VIA_3 lefdef VIA34
    via VIA_4 lefdef VIA45
    via VIA_5 lefdef VIA56
    poly POLYCIDE lefdef POLY1
    You can find some documentation on IR Drop Analysis at the following link:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/soceUG/soceUG9.1.3/power.html#1073877
  • yazdan
     Thanks for reply.
    So, you mean I should  write these file manualy by looking at technology file and lef file?
  • Scrivner
     Typically, this file should be provided by your technology library vendor. But if not, you can create it yourself.
