  3. Extraction Tech File for characterize_power_library command...
  • Subscribers 94
  • Views 15386
Extraction Tech File for characterize_power_library command of EPS
tungthanhhoang
tungthanhhoang over 15 years ago
Anybody can explain the content of "Extraction Tech File" that is used for command characterize_power_library command of EPS. If possible could you give some lines of this file and explain how we can obtain that file
Many thanks
/TH
  • Kari
    Kari over 14 years ago
     This file is usually provided by the foundry. It will be called the qrcTechFile. Before it was called that (if you're working with an older set of data), it was a .tch file. These files are not human-readable. If you have a .ict file (which is human-readable), you can use Techgen to build a .tch file.
  • DSubbu
    DSubbu over 14 years ago
    Hi ,
    Is this techgen part of SOC encounter.
    thanks & regards ,
    DSubbu
  • Kari
     Yes, it should be. Do a "which Techgen" and you should see it in the EDI install path. Note that the T must be capital!
