  3. FlipChip: create Bump 2 Bump connection with fcroute
  • Subscribers 94
  • Views 15382
The Consultant
The Consultant over 14 years ago
i have 2 Bumps ( signal-net is the same ) that i like to connect directly. Is there a way ?
  • Kari
    Kari over 14 years ago
     I'm not sure what your scenario is, but you can try this:
    srouteGrouteSerialBumpRouting TRUE
    you can put this statement in a text file, say it is called fc.ecf
    then
    setFlipChipMode -extraConfig fc.ecf
    then envoke fcroute, the extra config option will be used
    this is for straight connections of power bump to power bump connection, not designed for complex scenarios that need jogging etc.
