  3. nanoroute & fcroute
  • Subscribers 94
  • Views 2245
nanoroute & fcroute
The Consultant
The Consultant over 14 years ago
What is the difference between the two routers?
  • wally1
    wally1 over 14 years ago
    fcroute is for flip-chip routing from the bump to the IO driver. NanoRoute is for signal routing.
    Brian
  • The Consultant
    which classes do they route exactly ?
     nanoroute: BUMP, PAD, PAD AREAIO   ?
     fcroute: BUMP, CORE ?
    Regards
  • wally1
    fcroute is only used to make the connections to the bumps which is typically from the bump to the PAD AREAIO.
    NanoRoute is used to do the logic routing which includes routing between core logic (standard cells, hard macros) and also routing from the core logic to the pad.
    Hope that clarifies this.
