  3. SOC Encounter :: LEF File load Failed
  • Replies 13
  • Subscribers 98
  • Views 24279
Sohaib Qazi
Sohaib Qazi over 14 years ago
Hi
I am using SoC Encounter 10.1. While importing the design I load the netlist file (i.e. *.v file) and then add the LEF file to the list.
When I press OK then I get this error.
**ERROR: (ENCSYT-16013):
/sw/cadence/libraries/cmos065_522-2/CORL65LPSVT_5.1/CADENCE/LEF/
CORL65LPSVT_soc.lef failed
I am unable to resolve this issue.
Any suggestions ?
Qazi
  • Farshad78
    Farshad78 over 12 years ago +1
    Could you please let me know how your resolved the problem? Thanks
  • DavidMZ
    DavidMZ over 14 years ago
     There are no site rows in your design (and also, what are the blocks you say are missing? standard cells? power rings?)
      I still find your tech lef strange. If for example the unit defined is the micron, we see that you have a routing grid with a distance between the routing tracks (defined by the PITCH statement) of 10 microns, even though the default routing width (WIDTH statement) is 0.09 microns. The width can be more of course, but my point is that it seems illogical to allow a so small width with a distance a hundred times more important.
  • nannasin28
    nannasin28 over 13 years ago
    Make sure you have a tech lef and that it's the first lef that gets read in.
    LM2596
  • Farshad78
