  3. Re: RE: RTL compiler inner clock definition
  • Subscribers 93
  • Views 14718
gnangotzi
gnangotzi over 14 years ago
I have the same problem.
For synthesis with RC compiler I used the "creat_clock" command.
But when I import the design in Soc Encounter for place and route this is not good as the clock is generated by a macro analog block containing a VCO. For the digital fences, now, the clock has to be derived by the output pin of the analog block rather than by an input port. I don't know how to specify this.
Regards
  • Scrivner
    Scrivner over 14 years ago
    I think you just need to define your clock to be the maximum frequency that will be allowed by the VCO.
