  3. question about ELC 10.1, and really need help!
  • Subscribers 94
  • Views 14714
KyleJoe
KyleJoe over 14 years ago
   DESIGN        PROCESS       #ID         STATUS     IPDB
[WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error
this problem maybe happend to many other guys who used to design digital library, but I guess the reasons  are almost diffrent. I'm begging anyone can help me.
Flowing is my work  files
1.elccfg :
SETUP="setup1.ss";
PROCESS=”typical”;
SUBCKT="dut.scs";
MODEL="cor_std_mos.scs";
 2.setup.ss
Process typical {
voltage = 1.8   ; // as voltage
temp    = 25    ; /* as temperature */
Corner  ="tt";
Vtn     = 0.408 ;
Vtp     = 0.408 ;
Process best {
voltage = 1.92   ; // as voltage
temp    = 0    ; /* as temperature */
Corner  ="ff";
Vtn     = 0.472  ;
Vtp     = 0.472  ;
Process worst {
voltage     = 1.68   ; // as voltage
temp        = 125    ; /* as temperature */
Corner      ="ss";
Vtn = 0.392  ;
Vtp = 0.392  ;
Signal  std_cell {
unit  = REL  ;          // relative value
Vh    = 1.0  1.0 ;      // 100% rise/fall
Vl    = 0.0  0.0 ;
Vth   = 0.5  0.5 ;     // 50% rise/fall
Vsh   = 0.8  0.8 ;
Vsl   = 0.2  0.2 ;
tsmax = 1.0n     ;     // maximum output slew rate
Simulation std_cell {
transient    = 1.0n 60n  10p  ;
dc                      = 0.1 1.8 0.1;
bisec        = 6.0n 6.0n 10p ;  // binary search
resistance   = 10MEG;
Index X1{
    Slew = 0.100n 0.30n 0.7n 1.0n 2.0n;
    Load = 0.005p 0.0125p 0.025p 0.075p 0.15p;
Index X2{
    Load = 0.01p 0.025p 0.05p 0.15p 0.3p;
Index X4{
    Load = 0.02p 0.05p 0.1p 0.3p 0.6p;
Index X8{
    Load = 0.04p 0.1p 0.2p 0.6p 1.2p;
Index   CK_SLW {
bslew   = 0.0385n 0.5360n 1.0360n ;
Group   CK_SLW {
PIN = *.CK ;
Group   X1 {
CELL = *X1 ;
Group   X2 {
CELL = *X2 ;
Group   X3 {
CELL = *X3 ;
Group   X4 {
CELL = *X4 ;
Group   X6 {
CELL = *X6 ;
Group   X8 {
CELL = *X8 ;
Margin   m0 {
setup   = 1.0 0.0 ;
hold    = 1.0 0.0 ;
release = 1.0 0.0 ;
removal = 1.0 0.0 ;
recovery = 1.0 0.0 ;
width   = 1.0 0.0 ;
delay   = 1.0 0.0 ;
power   = 1.0 0.0 ;
cap     = 1.0 0.0 ;
Nominal  n0 {
delay   = 0.5 0.5 ; // as rise fall
power   = 0.5 0.5 ;
cap     = 0.5 0.5 ;
// Control Section
set process (best,typical,worst) {
simulation = std_cell ;
signal     = std_cell  ;
margin     = m0    ;
nominal    = n0    ;
set index  (best,typical,worst) {
        Group(XL)  = XL  ;
        Group(X1)  = X1  ;
        Group(X2)  = X2  ;
        Group(X3)  = X3  ;
        Group(X4)  = X4  ;
        Group(X6)  = X6  ;
        Group(X8)  = X8  ;
                Group(CK_SLW) = CK_SLW ;
3.command tcl files
   --step1.tcl--
db_open foo
set_var EC_SPICE_SIMPLIFY 1
set_var EC_HALF_WIDTH_HOLD_FLAG 1
set_var EC_SIM_NAME "spectre"
set_var EC_SIM_TYPE "spectre"
set_var EC_SPICE_SUPPLY1_NAMES "VDD"
set_var EC_SPICE_SUPPLY0_NAMES "VSS"
db_prepare
db_gate
db_close
exit
 ---step2.tcl
db_open foo
set_var EC_SIM_USE_LSF 1
set_var EC_SIM_LSF_CMD " "
set_var EC_SIM_LSF_PARALLEL 10
db_spice -s spectre -p typical -keep_log
db_close
exit
   After source the step2.tcl, the warning appeared.
elc> source step1.tcl
Database : foo is now opened
set_var EC_SPICE_SIMPLIFY = 1
set_var EC_HALF_WIDTH_HOLD_FLAG = 1
set_var EC_SIM_NAME = spectre
set_var EC_SIM_TYPE = spectre
set_var EC_SPICE_SUPPLY1_NAMES = VDD
set_var EC_SPICE_SUPPLY0_NAMES = VSS
==== Simplify Mode ====
MODEL FILE: cor_std_mos.scs ( #size = 110 )
- including rf018.scs : tt
- including rf018.scs : noiseflag
- including rf018.scs : mos
Reading MODEL: NCH
Reading MODEL: PCH
Reading MODEL: NCHMIS     in SUBCKT: NCH_MIS
Reading MODEL: PCHMIS     in SUBCKT: PCH_MIS
SUBCKT FILE: cor_std_mos.scs ( #size = 110 )
Reading SUBCKT:NCH_MIS
Reading SUBCKT:PCH_MIS
SUBCKT FILE: dut.scs ( #size = 631 )
Reading SUBCKT:NAND2X1
Expanding SUBCKT:NAND2X1
Writing : foo.ipdb/NAND2X1.design
Writing : foo.ipdb/NAND2X1.design/body/path
Writing : foo.ipdb/NAND2X1.design/body/instance
Writing : foo.ipdb/NAND2X1.design/body/net
Writing : foo.ipdb/NAND2X1.design/boundary/port
Writing : foo.ipdb/NCH.device
Writing : foo.ipdb/NCH.device/boundary/port
Writing : foo.ipdb/PCH.device
Writing : foo.ipdb/PCH.device/boundary/port
Reading : foo.ipdb/NAND2X1.design
      DESIGN : NAND2X1
        A   B  :  Y
D0000:  R   1  :  F  : DELAY(A)
D0001:  R   0  :  1  : POWER(A)
D0002:  F   1  :  R  : DELAY(A)
D0003:  F   0  :  1  : POWER(A)
D0004:  1   R  :  F  : DELAY(B)
D0005:  0   R  :  1  : POWER(B)
D0006:  1   F  :  R  : DELAY(B)
D0007:  0   F  :  1  : POWER(B)
=> 8 vectors generated
Writing : foo.ipdb/NAND2X1.design/simulate/spec
Writing : foo.ipdb/NAND2X1.design/simulate/subckt
Writing : foo.ipdb/NAND2X1.design/body/type
  stimulus generation  summary
Name        #MOS    #DVEC    #RVEC
NAND2X1        4    8    0
            8    0
 Reading setup file : setup1.ss
elc> db_close
Database : foo is closed
elc> source step2.tcl
set_var EC_SIM_USE_LSF = 1
set_var EC_SIM_LSF_CMD =
