  3. Query on Power/ground nets
  • Subscribers 92
  • Views 958
Anuragjn
Anuragjn over 13 years ago
Hi all,
I new to Encounter,hope u guys can resolve my issue
1. Actually in my design i have M7 vertical power net as vddm,but for this design im cutting the strap into half ,so the other half im naming as vddp, but when i dump out a lef i c the attribute set for vddp is GROUND.
So is ter a way to specify POWER to this net,as i used the folowing command to change the add name
addNet -physical vddp
createNetGroup vddp -net vddp
editChangeNet -to vddp
2. How to check the attribute of the PG net like if the selected net is power or ground as when i do reportSelect it doesnt show the required info other than voltage ,So is ter a way we can get the info on selected net
Anurag
  • Kari
    Kari over 13 years ago
    Hi Anurag,
    You don't need the createNetGroup or editChangeNet commands. In your .conf file, make sure you list all your power and ground nets:
    set rda_Input(ui_pwrnet) {VDD vddp vddm}
    set rda_Input(ui_gndnet) {VSS }
    etc....
    - Kari
