  3. Ideas for integrating a full-custom designed layout with...
  • Subscribers 94
  • Views 15101
Ideas for integrating a full-custom designed layout with a semi-custom designed microprocessor.
Thommandram
Thommandram over 14 years ago
I have verilog codes - (of a microprocessor design.), tell me a way to do the logic and physical synthesis which satisfies the below conditions:
I created register file/ RAM layout in cadence virtuoso. These register files are created with a novel architecture, and I want to add these in to the microprocessor design which is mentioned before.
Please note that I am not creating memory or a RAM for the microprocessor in verilog codes. I am creating a custom-designed layout in cadence virtuoso to create the RAM.
I want to know how to integrate the two design layouts together. Any suggestion/ ideas are welcome.
1 easy method which comes to mind : DO the logic synthesis in Cadence RTL Compiler in regular fashion and then, while creating the layouts in SOC Encounter, leave a seperate space in the floorplan for the custom designed layout. So that, it can be attached later.
Does this idea work? Kindly help me with an optimized design flow solution . please!!!
  • Scrivner
    Scrivner over 14 years ago
    The method you mentioned - creating the Place&Route layout of the micro and then place that layout and the memory layout together manually in virtuoso - that is the easiest way but makes timing verification between the micro and memory difficult.
    An alternate way is to create a blackbox LEF Macro and a timing model (liberty file) for your memory design. The LEF macro defines the physical boundary and pins of the memory.You can then import the LEF and lib file into SoC Encounter along with the netlist for the micro and run P&R. This allows you to create an integrated layout and verify timing between the micro and the memory.
  • Thommandram
    Thank you.
    Can you tell me how I can get started on writing example scripts for floorplan? I'm new to Soc encounter. I do have help files and reference manual. I think few example flows would help me understand.
