  3. how can i save power models i have created using build_rtl_power_models...
  • Subscribers 92
  • Views 13219
how can i save power models i have created using build_rtl_power_models ?
mamsadegh
mamsadegh over 13 years ago
Running build_rtl_power_models for creating power models in synthesis stage for the design takes a huge amount of time.
So practically, I don't see any advantage in running this command, since, the time it consumes to run can be used for running more precise power estimation algorithms.
Some where I read, when you created the model, you can save it and then re-load it for later use.
is that correct? how should I do this?
