  3. regarding non default rule of nets and wires
  • Subscribers 94
  • Views 16083
jaya sree
jaya sree over 14 years ago
Hai everyone,
In my project ,
when i run below command , i see that all nets have either "Track2X_Wide1X_Metal_0 non default rule" or default rule
selectInstByCellName ckbfxss*
dbGet selected.instTerms.net.rule.name
However when i run below command i see other non default rules also. "SNPS_DefGenNDR_3 SNPS_DefGenNDR_8 Track2X_Wide1X_Metal_0 SNPS_DefGenNDR_7 SNPS_DefGenNDR_9 SNPS_DefGenNDR_1 SNPS_DefGenNDR_10 SNPS_DefGenNDR_4 SNPS_DefGenNDR_2 SNPS_DefGenNDR_5 SNPS_DefGenNDR_6 SNPS_DefGenNDR_12 SNPS_DefGenNDR_11 SNPS_DefGenNDR_13 SNPS_DefGenNDR_14"
dbGet selected.instTerms.net.wires.rule.name
1) Does that means some of the wire segments of a net are routed with different rules? Why this is happening ?
2) How to select these wire segments.There is command selectNet to select nets. What is the commands to select wire segments.
It will be grateful if some one helps
  • wally1
    wally1 over 14 years ago
    I'm not sure why you see 2 different rules on the net. You can run the following to select wires for a specified rule. Change "double" to the rule you want to select segments for:
    set ruleName "double"
    set wireWithRulePtr [dbGet -p2 top.nets.wires.rule.name $ruleName]
    foreach wire $wireWithRulePtr {
      set netName [dbGet $wire.net.name]
      set box [lindex [dbGet $wire.box] 0]
      set layer [dbGet $wire.layer.name]
      eval editSelect -net $netName -area $box -layer $layer
    Hope this helps,
    Brian
