  3. NRDB-51 warning
  • Subscribers 94
  • Views 14288
NRDB-51 warning
gpremala
gpremala over 14 years ago
Hi All,
I am having Warnings after CTS,Route and PostRoute opt
WARNING (NRDB-51) SPECIAL_NET SG_rr is empty with no instance pin and special wire. Net with the same name will be routed but will not be connecte to the empty SPECIAL_NET.
The SG_rr net is too long and having approx. 30ns net delay.
By observing this I found that this net is HFN, and its net length is  approx. 14k microns, I did constarined signal net not to exceed 4000 microns.
But the tool is not able follow the net length constrain. and it doesnot add a buffer after 4000 microns.
Please provide me the solution on proper routing of HFN.
Tool SoC Encounter with version edi11.
Gopi
