  3. Special route "Error" in Encounter (error in Reading LEF...
  • Subscribers 92
  • Views 1218
Special route "Error" in Encounter (error in Reading LEF technology)
QQEDA
QQEDA over 13 years ago
Hi all,
When I trying to do Special route for Pad pins just after the power ring has done, the terminal shows the following err msg:
Reading LEF technology information...
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 374: cannot add PIN QA[0] to MACRO dp_rf_256x8 at or near "QA[0]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 386: cannot add PIN QA[1] to MACRO dp_rf_256x8 at or near "QA[1]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 398: cannot add PIN QA[2] to MACRO dp_rf_256x8 at or near "QA[2]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 410: cannot add PIN QA[3] to MACRO dp_rf_256x8 at or near "QA[3]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 422: cannot add PIN QA[4] to MACRO dp_rf_256x8 at or near "QA[4]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 434: cannot add PIN QA[5] to MACRO dp_rf_256x8 at or near "QA[5]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 446: cannot add PIN QA[6] to MACRO dp_rf_256x8 at or near "QA[6]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 458: cannot add PIN QA[7] to MACRO dp_rf_256x8 at or near "QA[7]"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 473: cannot add PIN VDD to MACRO dp_rf_256x8 at or near "VDD"
*ERROR* "data_files/macro/dp_rf_256x8/dp_rf_256x8.vclef", line 488: cannot add PIN VSS to MACRO dp_rf_256x8 at or near "VSS"
A total of 10 errors.
I had check the QA pins in netlist, it is connected. I also try to re-generate the memory model again and again, but still fails with the err msg.
Does anyone know how to fix it?
please help, thanks ^_^
  • wally1
    wally1 over 13 years ago
    This typically occurs when you've read in a LEF already that has MACRO dp_rf_256x8 defined. The cell can only be defined in multiple LEFs if one LEF contains the logical/physical info and the other LEF contains the process antenna info. When reading in the LEF files you must specify the antenna LEF file after the LEF containing the logical/physical info. Here is the order the LEFs should be listed so they are read in the proper order:
    1. Technology LEF
    2. LEF containing logical and physical information for the cells
    3. LEF containing process antenna rules and information.
    Hope this helps,
    Brian
  • QQEDA
    Dear  Brian(wally1) , thank you!!
    It's really work, I switch the order of those lef file like you said, and I can do the special route now, the msg has gone, yes!
    You just save my weekend. ^_^ ~~ yes!!
