  3. Regular Routing
  • Subscribers 94
  • Views 14300
Regular Routing
ahata
ahata over 14 years ago
 I would like to know if it's possible tu use only straight connections (no joggs) to route the cells using the encounter routing engine,i.e., to performt regular inter-cell routing. Is there any specific command to do this?? I'm using the globalDetailRoute command to route the cells, but is there any property which permits to use only straight connections? Btw, I'm using Encounter 10.12 version
 Thanks in advance for your help
