  3. The setup violation for the inclkSrc2reg paths in the layout...
  • Replies 14
  • Subscribers 92
  • Views 20532
The setup violation for the inclkSrc2reg paths in the layout designed by encounter
zhengyudennis
zhengyudennis over 13 years ago
Hi everyone,
  I am a learner of encounter (cadence) and meet the setup violation on the inclkSrc2reg group, which is shown as follows:
Path 1: VIOLATED Setup Check with Pin \DFF_1048/Q_reg /CLK
Endpoint:   \DFF_1048/Q_reg /D (^) checked with  leading edge of 'CK'
Beginpoint: g35                (v) triggered by  leading edge of 'CK'
Path Groups:  {inclkSrc2reg}
Other End Arrival Time          0.582
- Setup                         0.190
+ Phase Shift                   5.000
- Uncertainty                   0.100
= Required Time                 5.292
- Arrival Time                 13.369
= Slack Time                   -8.077
     Clock Rise Edge                      0.000
     + Input Delay                        0.200
     + Drive Adjustment                   0.717
     = Beginpoint Arrival Time            0.917
     Timing Path:
     |    Instance     |    Arc     |   Cell   |  Slew | Delay | Arrival | Required |
     |                 |            |          |       |       |  Time   |   Time   |
     |                 | g35 v      |          | 1.101 |       |   0.917 |   -7.160 |
     | U9357           | A v -> Y ^ | INVX1    | 3.186 | 5.666 |   6.583 |   -1.494 |
     | U9293           | A ^ -> Y v | INVX1    | 1.807 | 1.734 |   8.317 |    0.240 |
     | U8504           | A v -> Y ^ | INVX1    | 3.386 | 2.575 |  10.892 |    2.814 |
     | U8477           | A ^ -> Y v | INVX1    | 1.729 | 1.346 |  12.237 |    4.160 |
     | U6039           | A v -> Y ^ | OAI21X1  | 0.709 | 0.726 |  12.964 |    4.886 |
     | \DFF_1048/U4    | B ^ -> Y v | MUX2X1   | 0.710 | 0.171 |  13.135 |    5.057 |
     | \DFF_1048/U3    | A v -> Y ^ | INVX1    | 0.183 | 0.235 |  13.369 |    5.292 |
     | \DFF_1048/Q_reg | D ^        | DFFPOSX1 | 0.183 | 0.000 |  13.369 |    5.292 |
     + Drive Adjustment                   0.003
     = Beginpoint Arrival Time            0.003
     Other End Path:
     |                 | CK ^       |          | 0.021 |       |   0.003 |    8.081 |
     | CK__L1_I0       | A ^ -> Y ^ | CLKBUF2  | 0.043 | 0.086 |   0.089 |    8.167 |
     | CK__L2_I1       | A ^ -> Y ^ | CLKBUF3  | 0.058 | 0.124 |   0.213 |    8.290 |
     | CK__L3_I6       | A ^ -> Y ^ | CLKBUF2  | 0.040 | 0.094 |   0.307 |    8.384 |
     | CK__L4_I16      | A ^ -> Y ^ | CLKBUF3  | 0.039 | 0.116 |   0.424 |    8.501 |
     | CK__L5_I48      | A ^ -> Y ^ | CLKBUF1  | 0.047 | 0.071 |   0.495 |    8.572 |
     | CK__L6_I239     | A ^ -> Y ^ | CLKBUF1  | 0.069 | 0.087 |   0.581 |    8.659 |
     | \DFF_1048/Q_reg | CLK ^      | DFFPOSX1 | 0.069 | 0.001 |   0.582 |    8.660 |
Here, g35 is the input pin. I am a little bit confused that why the delay of U9357 (only a inverter) can be 5.666 ns. Further, all the setup violations happen on the inclkSrc2reg group. Can somebody tell me how to solve such problem? Thanks very much!
Best,
Dennis
  • Scrivner
    Scrivner over 13 years ago
    You may need to look at the fanout of the U9357 output. It may be that there is a large load due to a large fanout that is causing the large delay. Do you have a max_fanout constraint set? If not try adding this constraint to limit the number of gates each output drives. Also make sure you have set the max_transition constraint as well. The input transition on this device looks a little slow as well.
  • zhengyudennis
    Thanks very much for your suggestion. I use the .sdc file from DC for the timing driven layout design in Encounter. The max_fanout constraint is added in the script for DC compilation? In addition, for the max_transition constraint, where can I find its specific value? Thanks very much for your reply.
  • Scrivner
    You should add the max_fanout and max_transition constraint in both the synthesis constrains file and the Encounter constraints file. The best values to use for each constraint depend on the capabilities of the technology and the requirements of the design.
     To determine a good max_transition, you can look in the standard cell library .lib file and look at the transition timing tables for the clock inputs of flops and the inputs of buffers and inverters. Transition values near the middle of these table should give you a good idea of what typical transitions can be expected from the technology.
     For max_fanout, pick a reasonable number that still produces good transition times.
  • zhengyudennis
    Is the encounter constraint file only .sdc file or other files can be used? Thanks!
  • Scrivner
     The max_fanout and max_transition should be defined in the encounter constraint file which should be a standard .sdc file.
  • zhengyudennis
    After setting the max_fanout and max_transition, I found no influence on the layout design violation.How can I obtain the fanout number as well as capacitance on that rather small path in the encounter? Or should I get it in the PT?
  • Scrivner
     In Encounter you can use the report_net command to show the number of sinks and capacitance on the net:
     report_net -pin U9357/Y
  • zhengyudennis
    Thanks. It helps me a lot.
    Does Encounter have any power optimization during or after the layout design? Thanks very much for your help.
  • Scrivner
     I don't know much about power optimization in Encounter. I suggest reposting your power optimization question in the forum as a new subject to see if someone else can give you some guidance on that.
  • seourani
    seourani over 13 years ago
