  3. How to highlight a given list of ports in GUI (First Encounter...
  • Subscribers 94
  • Views 18990
How to highlight a given list of ports in GUI (First Encounter)
Anuragjn
Anuragjn over 14 years ago
Hi All,
I am new to First Encounter,Can any one help me out with a small tcl proc.
My query is how to highlight a given list of ports in GUI,Actually we can highlight ports using "Pin Editor" which works well.
But i have a file with a given list of ports (which does not consists all the design ports the one which requires to be highlighted is there in the file)
So is there a way to use this file and highlight them in GUI (either through command line or somewhere in GUI)
-Anurag
  • BobD
    BobD over 14 years ago
    Hi Anurag,
    dbForEachFileLine port.list line {
      highlight [dbGet -p top.terms.name $line] -index 1
    Notice that there's a difference between highlighting and selecting. Highlighting is typically used when you want to differentiate objects with different colors. Selection is more common when you want to select a group of objects. If you want to select use this instead of highlight:
    dbSelectObj [dbGet -p top.terms.name $line]
    Hope this helps,
    Bob
  • Anuragjn
    Thanks Bob for the solution it worked well :)
    The second command worked as i wanted to select the ports in gui and check how they were placed
    Just another query i tried the "highlight" command but it didnt work any additional specific command need to add for it to work
     -Anurag
