  3. routing missing in Virtuoso
  • Subscribers 94
  • Views 15675
quiet
quiet over 14 years ago
After P & R in Encounter, I stream out the design to gds. Then I stream in the file in Virtuoso.
I can see all the instances and the related power rings. But I can't see the routing wires.
What may be the problem?
Thanks.
  • wally1
    wally1 over 14 years ago
    The first thing I would check is make sure you have the NET object in your streamOut mapping file:
         layerName NET gdsNum dataType
    Then make sure you have that gdsNum/dataType defined in your mapping file for streaming into Virtuoso.
    - Brian
  • quiet
    Yes, I can find them in both two files.
    But I can see the nets for the power ring and power connections in the Virtuoso.
    Do power ring and interconnections use different layers?
    Thanks.
  • wally1
    Special Nets (typically power nets) and Signal Nets (also referred to as regular nets) are different object types in the Encounter database. So in the streamOut mapping file you'll specify them separately although you can map them to the same GDS layer number and datatype:
        layerName NET gdsNum dataType # This is for signal nets
        layerName SNET gdsNum dataType # This for special nets
    If the mapping files are correct and you have the layers displayed properly in Virtuoso, I'm not sure why you would not see them. I suggest opening a Service Request to get help with debugging this further.
    - Brian
