  3. Encounter export design to Virtuoso, OpenAccess
  • Subscribers 94
  • Views 15199
weebey
weebey over 14 years ago
Does anyone know how to properly export a design from Encounter into Virtuoso using OpenAccess? I keep running into problems when I try to do this. After loading my .conf in 'Import Design', I receive this error message:
 **ERROR: (SOCOAX-156): OA Exception : Could not access LibDef plug-in for oaLibDefSystem: #4: Shared Library Not Found: Error loading library 'libddbase_sh.so'. libddbase_sh.so: wrong ELF class: ELFCLASS32.
**ERROR: (SOCOAX-503): Can not open OA library 'test'. Make sure the library exists on disk and its entry is present in the library definition file.
I have created a lib.defs called 'lib.defs' file in my encounter directory, but it doesn't being read.
 Any help would greatly be appreciated. Thanks.
