  3. How to assign VIA to a net name?
  • Replies 12
  • Subscribers 96
  • Views 23326
mizzihood
mizzihood over 14 years ago
I'm having problems with adding/naming Vias. I select the "Add via", then "by geometry", specify it's geometry and put (click) it over an existing net. The problem however is, that the Via isn't connected to the net. The attribute window says it's net is _NULL.
I acquired the property value with:
>dbGet selected.net.name
and it returned _NULL as expected, however the counterpart command
>dbSet selected.net.name desired_name
returned "Attribute 'name' of object 'net' does not have set permission .....", which makes sense, sinse the attribute window didn't allow the change either.
The question therefore is how to tell a VIA that it belongs to a particular net, apart by crossing nets orthogonally?
regards
  • RaylonS
    RaylonS over 13 years ago
    I already had posted it as a new question, just the snippet you moved for me is a bit incomplete. I really appreciate the guidance though, and I apologize for my ignorance of the various Cadence tools / threads. I know it's important to keep things organized to get the best help, I will aim to do better in the future.
    Cheers Raylon
  • Kari
    Kari over 13 years ago
    No problem! It's kind of funny how the question can apply to both tools. :-) Sorry I didn't catch it sooner....
