  3. How to assign VIA to a net name?
  • Replies 12
  • Subscribers 96
  • Views 23325
mizzihood
mizzihood over 14 years ago
I'm having problems with adding/naming Vias. I select the "Add via", then "by geometry", specify it's geometry and put (click) it over an existing net. The problem however is, that the Via isn't connected to the net. The attribute window says it's net is _NULL.
I acquired the property value with:
>dbGet selected.net.name
and it returned _NULL as expected, however the counterpart command
>dbSet selected.net.name desired_name
returned "Attribute 'name' of object 'net' does not have set permission .....", which makes sense, sinse the attribute window didn't allow the change either.
The question therefore is how to tell a VIA that it belongs to a particular net, apart by crossing nets orthogonally?
regards
  • affaqq
    affaqq over 14 years ago
    I am on vacations so might not be able to respond timely. I will get back to work from 2nd Sept, 2012.
    Ciao!
    Affaq Qamar
    Mob:+3280294862
  • wally1
    wally1 over 14 years ago
    You can select the via then run "editChangeNet -to netName" to assign it to the desired net.
  • mizzihood
    Thank you!
  • RaylonS
    RaylonS over 13 years ago
    I tried using vias on GND as an example
    my entry was: editSelectVia -nets GND
    The response from the system was:
    E - Command not found: editSelectVia -nets GND
    Though I would be making progress if I could get that to work, I don't really want to change every single via of a net to a new net, just want to be able to select some vias (through whatever method) and assign them a net name.
  • Kari
    Kari over 13 years ago
    this method is only to select all the vias of a net, so it may not be what you want. however, i'm concerned that you got "command not found". it's like your encounter session is in some weird mode or something... can you post a screen shot of the command window maybe?
  • RaylonS
    Thanks again for working with me on this :)
     Screenshot shows post command entry response and my cursor hovering over a via on the net GND
     You're right though, in most cases I wont want to change very single via of a certain net, but my hope is once I figure this out, I can select vias with a different method and still apply the net change to them just the same. One step at a time...
  • Kari
    Well, that solves the problem. You are using a tool other than EDI (Encounter Digital Implementation) System. I don't know what tool that is. We may need to send your question to a different forum. :-)
  • RaylonS
    Ahh, yes I found the thread and didn't realize that "DI" was not appropriate. Since I am using Cadence PCB Editor 16.6, and this is a PCB Editor question I assumed it would be relevant - definitely my mistake! So there are more than 1 PCB layout tools by Cadence? Sheesh!
  • Kari
    EDI is not for PCB layout. It's for IC floorplanning/place&route/timing-closure/etc... I'll move your question to the PCB forum.
  • Kari
    I had trouble splitting the whole thread out - please check the PCB Design forum and make sure your question looks ok there. If not, please re-post there. Thanks!
