  3. How phase shift is calculated in timing report
  • Subscribers 95
  • Views 18513
gops
gops over 14 years ago
can someone please explain me in detail how phase shift is calculated in CTE. Attached is the picture in documentation. The explanation says that the most restrictive condition occurs at leading edge of CLK1(8) ad trailing edge of CLK2 (9).
But if these clocks are synchronous, how can it be assumed that both the clock starts at same time? In the diagram both clocks is shown as starting at the same time. I'm totally confused with the explanation. Someone please help.
  • affaqq
    affaqq over 14 years ago
    I am on vacations so might not be able to respond timely. I will get back to work from 2nd Sept, 2012.
    Ciao!
    Affaq Qamar
    Mob:+3280294862
