  3. reporting the standardcells in between two talking flop...
  • Subscribers 93
  • Views 13805
reporting the standardcells in between two talking flops
manu9
manu9 over 13 years ago
Hii everyone,
Can any one let me know if there is an option or command in the tool which can generate  all the cells in between two talking flops so that i can upsize,downsize only those set of cells or replace HVT with RVT or viceversa.
Thankyou
  • mohan kumar
    mohan kumar over 13 years ago
    you have to report timing using the option -from launch flop -to capture flop then it will report all the datapath cells in the report.
    Basically you need to change cells based on the timing analysis
  • manu9
     Yes,
    We do change cells based on timing,but the reason why I want to replace them is to make them a strong drivers with steeper transitions(to prevent or minimise the effect of Xtalk)
    NOTE: we can do this only when power is not a major concern.
    Thank you
