  3. Reading noise dealy report
  • Subscribers 94
  • Views 14862
Ganga111AtFPS
Ganga111AtFPS over 14 years ago
Hi all,
 Can any body explain how to analyse the following report.
I got this report after running xtalk in ETS.
        Noise Delay Report
        Generated: Tue Sep 13 01:12:14 2011
Report Options:
Slack     : yes
Delay     : max
Sort by   : absolute delay
Threshold : 10 (ps)
Type   Uncertainty(ps)  Delay(NomMax/Max)      VictimNet
R           295.524     616.136/911.661      tri_des_B/des3/u0/u2/p0694A:A1N {tri_des_B/des3/u0/n_676}
Constituents:
      Offset(ps) Slew(ps) Xcap(fF)  Edge  Net
Cpl:  4815.010   599.693    2.594     F   ~tri_des_B/des3/u0/n_676
Cpl:  5789.055   195.862    1.625     F   tri_des_B/des3/u0/n_672
Thanks in advance.
  • Kari
    Kari over 13 years ago
    You can see that the victim net is labeled ( tri_des_B/des3/u0/n_676).
    To find the agressor net(s), look at the "constituents" section. The agressor net is  tri_des_B/des3/u0/n_672. If you have a glitch or noise-on-delay for your victim net, this agressor is the one you want to separate it from. Likely, these two nets have a long parallel run. The "net" that matches the victim, but has a ~ in front of it, is all the other little things in the design that add up to SI effects, so it's not a real net you can look at in the design. Just address the real aggressor and you should be able to fix the SI problem.
