  3. How to find dont use cells in thedesign using dbGet com...
  • Subscribers 94
  • Views 20157
How to find dont use cells in thedesign using dbGet command
gpvarma
gpvarma over 14 years ago
 Hi All,
as i now we can find the don't use cells in the design using get_attribute command. But i want to find don't use cells in the design using dbGet  commands.
Thank you
Phanendra
  • wally1
    wally1 over 14 years ago
    Hi Phanendra,
    Here a script to do this taken from solution 11701286 (http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11701286).
    Brian
    Problem
    Is there a way to get (in tcl) the setting of the setDontUse on a particular cell ?
    I know I can use the reportDontUse command, but I didn’t find a way to get the true/false setting of the cell returned/captured into a tcl variable.
    Solution
    Please use the following script :
    foreach_in_collection libCell [get_lib_cells *] {
      set name [get_property $libCell name]
      set cellP [dbGetCellByName $name]
      puts "$name [dbIsCellDontUse $cellP]"
    This script will identify all cells marked dont_use using any of these methods :
         - if the user sets it interactively using setDontUse.
         - if the library cell has "dont_use : true" set in the .lib
         - if the SDC has set_dont_use
  • gpvarma
     Hi Brain,
    Thank you very much for your info.
    Phanendra
