  3. Cadence Encounter doesn't fix hold violations?
  • Subscribers 93
  • Views 1866
FormerMember
FormerMember over 14 years ago
Hi everyone,
please help me with the next problem:
I'm designing a digital IC based on FPGA-verified source code using Cadence tools: Encounter for P&R and optimization and Incisive simulator (NCSim may be the second name) for checking the resulting waveforms.
After P&R, in post-route stage, I optimized design using the next commands:
optDesign -postRoute
optDesign -postRoute -hold
and the results are:
| Setup mode | all | reg2reg | in2reg | reg2out | in2out | clkgate |
| WNS (ns):| -0.021 | -0.021 | 0.044 | N/A | N/A | N/A |
| TNS (ns):| -1.751 | -1.751 | 0.000 | N/A | N/A | N/A |
| Violating Paths:| 356 | 356 | 0 | N/A | N/A | N/A |
| All Paths:|3.64e+05 |2.45e+05 |1.19e+05 | N/A | N/A | N/A |
| Hold mode | all | reg2reg | in2reg | reg2out | in2out | clkgate |
| WNS (ns):| 0.031 | 0.038 | 0.031 | N/A | N/A | N/A |
| TNS (ns):| 0.000 | 0.000 | 0.000 | N/A | N/A | N/A |
| Violating Paths:| 0 | 0 | 0 | N/A | N/A | N/A |
I know that setup violations were not fixed correctly, but hold were.
After that, I extracted the resulting netlist and SDF file and annotated them to simulator, and there are more timing violations in it's log file, but only HOLD. I think that setup violations were fixed decreasing the clock frequency in testbench, but, of course, HOLD not.
A part of ncsim.log file:
Warning! Timing violation
$setuphold<hold>( posedge CK &&& (ENABLE_RB === 1'b1):3236050 PS, negedge E &&& (ENABLE_RB === 1'b1):3236050 PS, 1.0 : 10 PS, 1.0 : 10 PS );
File: ./uk65lscsp10bbrccs_sdf30.v, line = 33170
Scope: :UUT.bis64.B_E.\tmp_reg[33]
Time: 3236050 PS
Scope: :UUT.bis64.B_E.\tmp_reg[34]
Time: 3236050 PS
How can I fix hold violations in encounter? What I need to do? Please note, the program says that there are no hold violations in design.
Thanks in advance,
Kuxx.
