  3. Macros Placement
  • Subscribers 94
  • Views 17855
Macros Placement
IrfanD
IrfanD over 14 years ago
 Hi All,
I have a design with many ram macros. We have created special SITEs for these macros in the floorPlan DEF. SITES are in coulumns of two macros side by side.  The size of the the SITES is exactly same as the macros.  If I let encounter do the placement. It was  not honoring the SITE info for these macros and keep placing them all over.  Is this the right way to do  large number of macro placements??
Irfan
  • wally1
    wally1 over 14 years ago
    Hi Irfan,
    SITEs are usually only intended for standard cells and IO pads. To place blocks you can use Relative Floorplanning which includes an option to create an array of blocks. Here's a solution with examples:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11649020
    Or Floorplan Synthesis which is a more automated flow:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs
    ;q=soceUG/soceUG11.2/masterplan.html#1036843
    Hope this helps.
    Brian
  • IrfanD
    IrfanD over 13 years ago
    Thanks Brian,
    I will look into relative fllorplaning with array option doc. Right now online support is not working for us.  Meanwhile I did an experiment by chaning Macros to class CORE and was able to see them  placed at the correct SITEs.  Gert ( Cadence AE) did mention that its not a good idea going forward, macros should remain of class BLOCK. In out case power structure for these Macros is already available in a cover cell.
     Also floorplan synthesis will be good option for me to look into. I am thinking of running a floorplan sysnthesis and obtain optimum marco placement then write a script to place these macros at the closes available site.
    Irfan
