  3. Captable
  • Subscribers 93
  • Views 15536
Captable
archive over 13 years ago
 Hi All,
I have a doubt regarding the contents contained in the captables.
What is the Exact difference between basic captable and Extended captable sections in the captable file.
  • wally1
    wally1 over 13 years ago
    Here is information that explains the differences. If you believe something is wrong with the captable it is probably best to open a Service Request to get help debugging it.
    ParagraphBullet
    Basic Captable Part: Contains the coefficients used by the preRoute capacitance extraction engine. This part contains the area, fringe, and lateral coupling capacitance coefficients organized per conductor layer for wires with different width and spacing. The basic captable part is presented in a readable tabular format.
    ParagraphBullet
    Extended Captable Part: Contains the coefficients used by the postRoute -effortLevel low capacitance extraction engine. This part is much larger compared to the basic captable part because the coefficients are generated on more complex profiles, which account for geometries on multiple layers. The extended captable part is an ASCII dump of the binary stored data
     - Brian
     Thanks wally
    I have the underastanding as stated below
    Basic captable will generate by considering only one conducting layer geometries , But extended cap table will genereate by considering the geometries of all layers on a perticular layer . Is My understanding correct?
