  3. open the GUI
  • Subscribers 94
  • Views 32560
open the GUI
ErezBS
ErezBS over 13 years ago
Can i open the gui after starting encounter with "encounter -nowin"?
 Thanks.
  • AndreasLenz
    AndreasLenz over 13 years ago
    You can't open a GUI starting with nowin. The graphic initialization doesn't happen if you start with -nowin. Alternative start encounter without nowin, use the win off command to disappear the GUI and win to raise it again.
    Cheers
      Andreas
  • ErezBS
    thanks!
  • Syeda Fayiza
    Syeda Fayiza over 8 years ago in reply to ErezBS
    Please let me know ,how to invoke INNOVUS tool from terminal.
    What parameter should be set in cshrc file ,So that if i type "innovus" in terminal it should invoke the tool.
    Fayiza
  • Kari
    Kari over 8 years ago in reply to Syeda Fayiza
    You need to have the installation in your path. If you type "which innovus" you should see the path where it is installed. You may need to get your local IT support to help.
