  3. SPEF differ between timeDesign and extractRC
  • Subscribers 94
  • Views 16452
steven2012
steven2012 over 13 years ago
Hi Bob & Kari
I did the following things,why the spef from "timeDesign -signoff -si" is different to the spef from "extractRC".
1. spef_01.spef.gz (one way)
setExtractRCMode -engine postRoute -effortLevel signoff -coupled true -lefTechFileMap qrc.layermap
so,the spef file "spef_01.spef.gz" will be extracted.
 2. spef_02.spef.gz (another way)
extractRC
so,the spef file "spef_02.spef.gz" will be extracted.
but,why there are slight difference between "spef_01.spef.gz" and "spef_02.spef.gz" and which is more suitable to use?
Thanks advance!
Best Regards.
  • Kari
    Kari over 13 years ago
    your second way does not include the SI analysis.
  • steven2012
    Hi Kari
    Thank you for reply.I think the option "-couple true" will force the command extractRC to
    extract the si spef.
    so,in my opinion the above two spef should be same,however there are subtle differences between them.
  • Kari
    My guess is that timeDesign -si triggers some other extraction variables/thresholds/etc. to be set, causing the small differences. But as I said that is a guess. If your flow is dependent on this, I would suggest filling a service request.
