  3. Encounter terminated by internal (SEGV) error/signal...
  • Subscribers 93
  • Views 1947
aga1214
aga1214 over 13 years ago
I was trying to click Ruler(K) Button on the encounter screen , Encounter dies with the message "Encounter terminated by internal (SEGV) error/signal...".  is there any suggestion to solve it ?  thanks
My encounter version:8.1    system is CentOS 6.2, 64 bit
the log file is below:
 @(#)CDS: First Encounter v08.10-p004_1 (32bit) 11/04/2008 14:34 (Linux 2.6)
@(#)CDS: NanoRoute v08.10-p008 NR081027-0018/USR58-UB (database version 2.30, 67.1.1) {superthreading v1.11}
@(#)CDS: CeltIC v08.10-p002_1 (32bit) 10/23/2008 22:04:14 (Linux 2.6.9-67.0.10.ELsmp)
@(#)CDS: CTE v08.10-p016_1 (32bit) Oct 26 2008 15:11:51 (Linux 2.6.9-67.0.10.ELsmp)
@(#)CDS: CPE v08.10-p009
--- Starting "First Encounter v08.10-p004_1" on Fri Dec 28 09:40:24 2012 (mem=62.2M) ---
--- Running on localhost (x86_64 w/Linux 2.6.32-220.el6.x86_64) ---
This version was compiled on Tue Nov 4 14:34:21 PST 2008.
Set DBUPerIGU to 1000.
Set Default Mode Total Cap Scale Factor to 1.00
Set Detail Mode Total Cap Scale Factor to 1.00
Set Coupling Total Cap Scale Factor to 1.00
Set Total Res Scale Factor to 1.00
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
<CMD_INTERNAL> uiSetTool ruler
*** Stack trace:
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(syStackTrace+0x146)[0xd1c3d2f]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter[0x8bc653e]
[0xf77aa410]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z14winTextExtentsP7winsWinP9winsLayerPcPiS4_S4_+0x75)[0xc571c0d]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z12winDrawRulerP7winsWinP9winsRulerP9winsLayeri+0x408)[0xc5b23c0]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z21winEventDrawEditRulerP7winsWinP14winsEventQueue+0x47)[0xc5b2af5]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z15winEventDrawRubP7winsWin+0x50)[0xc5abba4]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z10winDisplayP7winsWin+0x1c2)[0xc57091c]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter[0xc57323a]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(TclServiceIdle+0x59)[0xe0e74f9]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(Tcl_DoOneEvent+0x16e)[0xe0d7e8e]
/home/cad/layout/encounter/encounter/tools/lib/libtq.so(_ZN17TqEventDispatcher13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0xb6)[0xf633007a]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x31)[0xf670b981]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x7a)[0xf670ba8a]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0xa6)[0xf670e016]
/home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtGui.so.4(_ZN12QApplication4execEv+0x27)[0xf6929587]
/home/cad/layout/encounter/encounter/tools/lib/libtq.so(_ZN13TqApplication4execEv+0x320)[0xf6332568]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_Z7fe_mainiPPc+0x33c)[0x8ba95f0]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(main+0x79)[0x8ba96b7]
/lib/libc.so.6(__libc_start_main+0xe6)[0x8b1ce6]
/home/cad/layout/encounter/encounter/tools/fe/bin/32bit/encounter(_ZN7QDialog13keyPressEventEP9QKeyEvent+0x2b5)[0x8ba8cc1]
               pstack
Thread 4 (Thread 0xf49e4b70 (LWP 11694)):
#0  0xf77aa430 in __kernel_vsyscall ()
#1  0xf7777c26 in nanosleep () from /lib/libpthread.so.0
#2  0x093790de in rdaiLicRecheck(void*) ()
#3  0xf7770a09 in start_thread () from /lib/libpthread.so.0
#4  0x0097800e in clone () from /lib/libc.so.6
Thread 3 (Thread 0xf3fe3b70 (LWP 11695)):
#1  0x009704f1 in select () from /lib/libc.so.6
#2  0x0e0fa66c in NotifierThreadProc ()
Thread 2 (Thread 0xf35e2b70 (LWP 11696)):
#1  0xf7778590 in sigwait () from /lib/libpthread.so.0
#2  0x08bc69b7 in ctrlCHandle(void*) ()
Thread 1 (Thread 0xf61da700 (LWP 11647)):
#1  0x00937d3b in waitpid () from /lib/libc.so.6
#2  0x008d4293 in do_system () from /lib/libc.so.6
#3  0x008d4622 in system () from /lib/libc.so.6
#4  0xf77787ad in system () from /lib/libpthread.so.0
#5  0x0d1c3d96 in syStackTrace ()
#6  0x08bc653e in rdaiErrorHandler(int, siginfo*, void*) ()
#7  <signal handler called>
#8  0x0058f751 in XTextExtents () from /usr/lib/libX11.so.6
#9  0x0c571c0d in winTextExtents(winsWin*, winsLayer*, char*, int*, int*, int*) ()
#10 0x0c5b23c0 in winDrawRuler(winsWin*, winsRuler*, winsLayer*, int) ()
#11 0x0c5b2af5 in winEventDrawEditRuler(winsWin*, winsEventQueue*) ()
#12 0x0c5abba4 in winEventDrawRub(winsWin*) ()
#13 0x0c57091c in winDisplay(winsWin*) ()
#14 0x0c57323a in winiTkDisplay(void*) ()
#15 0x0e0e74f9 in TclServiceIdle ()
#16 0x0e0d7e8e in Tcl_DoOneEvent ()
#17 0xf633007a in TqEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/lib/libtq.so
#18 0xf670b981 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#19 0xf670ba8a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#20 0xf670e016 in QCoreApplication::exec() () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtCore.so.4
#21 0xf6929587 in QApplication::exec() () from /home/cad/layout/encounter/encounter/tools/Qt/32bit/lib/libQtGui.so.4
#22 0xf6332568 in TqApplication::exec() () from /home/cad/layout/encounter/encounter/tools/lib/libtq.so
#23 0x08ba95f0 in fe_main(int, char**) ()
#24 0x08ba96b7 in main ()
                gdb
Using: gdb
[Thread debugging using libthread_db enabled]
[New Thread 0xf35e2b70 (LWP 11696)]
[New Thread 0xf3fe3b70 (LWP 11695)]
[New Thread 0xf49e4b70 (LWP 11694)]
A debugging session is active.
    Inferior 1 [process 11647] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
*** INTERRUPTED *** [signal 1]
11647: No such process
