  3. Setting Clock Input Transition Value When Pin Defined at...
  • Subscribers 94
  • Views 16143
Setting Clock Input Transition Value When Pin Defined at Instance Output
JAUB
JAUB over 13 years ago
Quick CTS question (EDI 10.1.3) . When the clock root is defined at the output , such as
AutoCTSRootPoint   someInstanceName/Y
How do I set the input transition value for the clock root ?
I cannot use RootInputTran in the clock spec file to specify the input transition at the clock root since the clock is not specified at an input pin/port.
The clock report shows  that CTS used the default root input tran value of 1ps which is way to fast for this design (periods for clocks 47ns and 100ns).
  I recall seeing something about a setting/variable to tell CTS to take the driving cell into account to avoid using the default, but I cannot locate it in the docs or through online search.
 Any suggestions ?
 Thank You,
Jeff Aubert
  • Kari
    Kari over 13 years ago
    Hi Jeff,
     Does this do what you want?
    set_global timing_clock_source_use_driving_cell true
    - Kari
