  3. Issue regarding Clock Tree Synthesis
  • Subscribers 94
  • Views 15789
Arslan
Arslan over 13 years ago
Hi, while performing clock tree synthesis, one has to provide list of inverters and buffers in  "generate clock specs" by selecting from the list of available cells. this list is missing in my case. any ideas how to get the list.?
  • BobD
    BobD over 13 years ago
    The tool is able to automatically select clock buffers. Use "clockDesign" and it will automatically create a clock tree spec file from your SDCs. To influence how the clock tree spec file is created, a combination of setCTSMode and specifyClockTree are typically used in conjunction with this command. specifyClockTree -create/-update/-delete can be used for programmatic modification of a clock tree spec file. Hope this helps!
  • Arslan
    the tool should automatically select clock buffers, but in my case it is not doing that. And even if I manually write .ctstch file and specify buffers, it gives following warning and error
    **WARN: (ENCCK-994):    Cell BUF_X0P5B_A12TL_C31 has no timing arc. Check The timing libraries.
    **ERROR: (ENCCK-724):
     Buffer BUF_X0P5B_A12TL_C31 specified in the clock tree specification file is invalid.
    I have checked and this cell is present both in .lib and macro lef.
    regarding the warning, following data is present in .lib and as far as I think timing arc is present.
    pin(Y) {
          direction : output ;
          function : "A" ;
          max_capacitance : 0.0559642 ;
          max_transition : 0.629333 ;
          min_capacitance : 0.0001 ;
          output_voltage : default ;
          related_ground_pin : VSS ;
          related_power_pin : VDD ;
          power_down_function : "!VDD + VSS" ;
          internal_power() {
            related_pin : "A" ;
            fall_power(pwr_tin_oload_7x7) {
              index_1("0.00221333, 0.0134941, 0.0530922, 0.12871, \
                      0.24652, 0.41182, 0.629333");
              index_2("0.0001, 0.0011049, 0.00463232, 0.0113684, \
                      0.021863, 0.036588, 0.0559642");
              values("0.000799615, 0.000809414, 0.000804709, 0.000799901, 0.000796933, 0.000794658, 0.000793265",\
                     "0.000779447, 0.000791893, 0.000794127, 0.000789831, 0.00078605, 0.00078341, 0.000781609",\
                     "0.00075481, 0.000764512, 0.000771666, 0.000772847, 0.000771287, 0.000769781, 0.000768644",\
                     "0.000740172, 0.000748833, 0.000758996, 0.000761591, 0.000762006, 0.000761375, 0.000760505",\
                     "0.000733962, 0.000740326, 0.000751239, 0.000757472, 0.000757939, 0.000758445, 0.000758127",\
                     "0.000732756, 0.00073781, 0.000748783, 0.000756138, 0.000759203, 0.000758949, 0.000759207",\
                     "0.000737063, 0.000742102, 0.000751108, 0.000758366, 0.000763561, 0.000764869, 0.000764537");
            rise_power(pwr_tin_oload_7x7) {
              values("0.000398047, 0.000399094, 0.000368668, 0.000309951, 0.000217467, 8.96784e-05, -9.89654e-05",\
                     "0.000379525, 0.000381884, 0.00035439, 0.000296803, 0.000208909, 8.21009e-05, -9.57076e-05",\
                     "0.000359822, 0.000369113, 0.000336634, 0.000283114, 0.000192421, 6.7156e-05, -0.000111223",\
                     "0.000347169, 0.000355357, 0.00036125, 0.000273792, 0.000183245, 6.04281e-05, -0.000124907",\
                     "0.000339577, 0.000346178, 0.000354397, 0.000354857, 0.000183655, 4.95099e-05, -0.000117814",\
                     "0.000337152, 0.000341429, 0.000348397, 0.000346551, 0.000330806, 6.69343e-05, -0.000116624",\
                     "0.000338414, 0.00034255, 0.00034286, 0.000347778, 0.000350767, 0.000347991, -3.63895e-05");
          timing() {
            related_pin : "A" ;
            timing_sense : positive_unate ;
            timing_type : combinational ;
            cell_fall(tmg_ntin_oload_7x7) {
              values("0.0158512, 0.0223217, 0.0437717, 0.0847096, 0.148543, 0.238134, 0.356032",\
                     "0.0215605, 0.0280732, 0.0496417, 0.0905883, 0.15441, 0.24399, 0.361885",\
                     "0.0380775, 0.044788, 0.0664424, 0.107434, 0.17126, 0.260836, 0.378723",\
                     "0.0616066, 0.0692005, 0.0909026, 0.131875, 0.195689, 0.285233, 0.403102",\
                     "0.0895357, 0.0991638, 0.121553, 0.162355, 0.22609, 0.315587, 0.433413",\
                     "0.120292, 0.132682, 0.157371, 0.197968, 0.261518, 0.350912, 0.468664",\
                     "0.152779, 0.168385, 0.197076, 0.237967, 0.301225, 0.390433, 0.508057");
            cell_rise(tmg_ntin_oload_7x7) {
              values("0.0200719, 0.0251704, 0.0402318, 0.0685235, 0.112603, 0.174458, 0.255851",\
                     "0.0255913, 0.0306991, 0.0458071, 0.0741014, 0.118175, 0.180023, 0.261416",\
                     "0.0426747, 0.0480412, 0.0633147, 0.0916258, 0.135679, 0.197513, 0.278893",\
                     "0.066668, 0.0727648, 0.0883858, 0.116703, 0.16075, 0.222548, 0.303888",\
                     "0.094421, 0.101884, 0.118338, 0.146575, 0.190562, 0.25233, 0.333632",\
                     "0.124006, 0.1334, 0.151575, 0.179844, 0.223647, 0.285321, 0.366576",\
                     "0.154086, 0.165775, 0.186688, 0.215439, 0.258964, 0.32046, 0.401606");
            fall_transition(tmg_ntin_oload_7x7) {
              values("0.00774636, 0.0185995, 0.0577129, 0.132635, 0.249353, 0.413141, 0.628703",\
                     "0.00785682, 0.0186233, 0.0577083, 0.132623, 0.249377, 0.413176, 0.628734",\
                     "0.00920592, 0.019244, 0.0578494, 0.132662, 0.249379, 0.413151, 0.628711",\
                     "0.0130111, 0.0215641, 0.0583874, 0.132889, 0.249473, 0.41318, 0.628679",\
                     "0.019134, 0.0269453, 0.0600547, 0.133387, 0.249743, 0.41337, 0.628744",\
                     "0.0270202, 0.035272, 0.0642992, 0.134499, 0.250249, 0.413648, 0.628994",\
                     "0.0365, 0.0457262, 0.0721991, 0.13721, 0.251165, 0.414188, 0.629311");
            rise_transition(tmg_ntin_oload_7x7) {
              values("0.00832464, 0.0157314, 0.0433071, 0.0975357, 0.182286, 0.301218, 0.457735",\
                     "0.00836245, 0.0157446, 0.043311, 0.0975335, 0.182272, 0.301202, 0.457707",\
                     "0.00977667, 0.0167199, 0.0436751, 0.0976212, 0.182299, 0.301206, 0.457723",\
                     "0.0133544, 0.0194572, 0.0448837, 0.0981831, 0.182608, 0.301347, 0.457773",\
                     "0.0191592, 0.0244967, 0.0474023, 0.0992111, 0.183248, 0.30182, 0.458047",\
                     "0.0268718, 0.032019, 0.0520368, 0.101128, 0.184192, 0.302516, 0.458584",\
                     "0.0362388, 0.0416758, 0.0594135, 0.104635, 0.185688, 0.303445, 0.459354");
