  3. Max min timing lib.
  • Subscribers 94
  • Views 15571
Max min timing lib.
Arslan
Arslan over 13 years ago
Is it necessary to provide both max and min timing libs while synthesizing. If so then min timing lib field is missing in my case. I have Soc Encounter v11.10 installed...where should i give min timing libs.
  • BobD
    BobD over 13 years ago
    Min libs are not necessary for synthesis but are almost always used in a backend flow. Use File->Import->Create Analysis Configuration to establish a Mulit-Mode/Multi-Corner (MMMC) timing environment. At least one setup "view" and one hold "view" are required. If you only want to optimize for a single mode and corner you can specify the same view for both setup and hold. Hope this helps.
  • Arslan
