  3. Encounter -> Report Power using VCD
  • Subscribers 93
  • Views 5410
Terry2000
Terry2000 over 12 years ago
I've generating a Power Report using a VCD file for activity:
1. Exported netlist from encounter.
2. Used this netlist in ncsim and generated VCD file
3. Read in the activity file into encounter, this is the cmd generated from the menu:
read_activity_file -report_missing_nets true -format VCD -scope u_bon5000_toplevel -start {} -end {} -block {} ../ATPG/RESULTS/bon5000_test.vcd
  Filename (activity)                    : ../ATPG/RESULTS/bon5000_test.vcd
  Names in file that matched to design   : 1557/1924
  Annotation coverage for this file      : 1557/2080 = 74.8558%
INFO (POWER-2168): Current Memory Usage : 1,150Mb bytes at 2013-Feb-04 14:38:56(2013-Feb-04 14:38:56 GMT)
  367 nets were found in the VCD file(s) but were not in
  the design.  These nets are listed in the log file eps.logv .
  Total annotation coverage for all files of type VCD: 1557/2080 = 74.8558%
  Percent of VCD annotated nets with zero toggles: 198/2080 = 9.51923%
4. I am not getting 100% annotation of nets. I've used the -report_missing_nets to try and debug the unannotated nets however no debug information is written either the the display and there is no sign of an eps.logv file anywhere in the database.
 Any idea's how to debug the missing annotated nets ????
  • Kari
    Kari over 12 years ago
    make sure the scope is correct. if you remove "u_bon5000_toplevel" from the names in the VCD, do they now match your design?
  • Terry2000
    Hello Kari,
    Thanks for your reply, I managed to debug the issue a few days back.
    The magic command to see what nets were not being annotated is:
    dump_unannotated_nets -file <filename> -type annotationType vcd
    It was then very esy to debug the issue, it was the lack of any logfile that was my issue debugging the problem.
    The problem was indeed an issue with the scope statement in my VCD file.  Seem to recall the scope instance from a VCD generated from an ET testbench needed a slight tweek when being used in EDI.
    Cheers
    Terry
  • Saurav Khosla
    Saurav Khosla over 9 years ago
    Hello Terry,
    I am facing trouble in defining the scope instanance from VCD.
    This is how I have read the verilog and VCD. I get 0% annotation.
    read_verilog {/projects/sos_wa/dft/dft_release/power_analysis/release_201611/chiptop_macau_a1.v /projects/sos_wa/power_analysis/release_20160211/digital_top.v}
    set_top_module digital_top -ignore_undefined_cell
    read_activity_file /projects/dft_release/power_analysis/release_20160211/ROM.vcd \
    -format VCD -start 0 -end 455450002 -scope {{chiptop_mfgd_a1_membistv_1_testbench_v_ctl.fg_a1_inst.I7.I15}}
    Names in file that matched to design : 0/0
    Annotation coverage for this file : 0/237015 = 0%
    Total annotation coverage for all files of type VCD: 0/237015 = 0%
    Percent of VCD annotated nets with zero toggles: 0/237015 = 0%
    ** INFO: (VOLTUS_POWR-1356): No default input activity has been set. Defaulting to 0.2.
    Activity annotation summary:
    Primary Inputs : 2/112 = 1.78571%
    Flop outputs : 0/40558 = 0%
    Memory/Macro outputs : 0/857 = 0%
    Tristate outputs : 0/0 = 0%
    Total Nets : 10/237015 = 0.00421914%
    Please guide.
  • Kari
    Kari over 9 years ago
    first check that the scope is correct. you may need to talk to whoever generated the VCD. Also, was the VCD generated from the netlist that you are using? If it was generated for an earlier version of the netlist that does not match, you can have annotation problems.
